Exhaust offset question (No tip magnaflow owner)
Heya
What tip offset do i need for a 5th generation hatch ?
this :
this :
or this ?
I'd personally say the 2nd, but i dont know...btw, i'll be using a magnaflow full catback (if the axel back matter).
thanks
-Pat
this :
this :
or this ?
thanks
-Pat
I needed the center in/offset out for my frields hatch. The Magnaflow unit is a straight-through design and there will be no noticeable loss if you don't use the center/center muffler. The core in the center/offset unit is only a very slight "s" curve.
if you get an axleback, then you'd need proper offset,
basically you'd need to get the right setup for your car..
but if your just getting a magnaflow muffler and having the piping made, then you can have it made so it lines up wherever
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tad »</TD></TR><TR><TD CLASS="quote">if you get an axleback, then you'd need proper offset,
but if your just getting a magnaflow muffler and having the piping made, then you can have it made so it lines up wherever</TD></TR></TABLE>
Yes, but the center inlet makes for a straight shot through the suspension.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pat »</TD></TR><TR><TD CLASS="quote">i'll be using a magnaflow full catback (if the axel back matter).</TD></TR></TABLE>
i'll get offset/center one, thanks !
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STN_Pat »</TD></TR><TR><TD CLASS="quote">i'll get offset/center one, thanks !
... dont they have one specifically made for your car???
choose that, maybe its offset.. maybe its not...
maybe its common sense
</TD></TR></TABLE>... dont they have one specifically made for your car???
Broertje
Mar 2, 2012 07:48 AM
pdiggitydogg
Nov 16, 2004 09:09 PM
