Offset/Center Muffler
Old Dec 2, 2008 | 03:58 PM
4dooritr's Avatar
Default Offset/Center Muffler
I know must of you go with the Center/Center inlet/outlet muffler's.
However I have a Dynomax super turbo which is Offset inlet and center outlet.
Does anyone have pictures of a offset/center muffler on their car
this is a 94 DB8, I got the muffler cause its big,quiet, 2.5", flows good and looks more stock then other muffler's
Anyone have experince or ever seen one installed?
thanks
Old Dec 2, 2008 | 04:37 PM
HondaLove517's Avatar
I install them on hondas all the time at my shop for factory replacments. Personally it looks fine but just a matter of taste. Remember from. That center to offset might only be roughly 2-4 inches so might not be that noticable
Old Dec 2, 2008 | 04:50 PM
4dooritr's Avatar
what about offset inlet to center outlet.
Old Dec 2, 2008 | 05:09 PM
Well depends what your doing with the exhaust. If you're doing it as a bolt on or an exhaust shop welding. If it were me I would remake the over axle pipe to keep the muffler in the correct exit location and just change up the inlet. If your doing a bolt on it depends which way the inlet went. One way will push the muffler to the passenger side and it more than likely wont work because it'll be against it and probably not mount right. If it's going the other way towards the drivers it should be ok just a little over from factory. You best bet in my opinion is to have an exhaust shop weld it up and remake the over axle pipe.
Old Dec 2, 2008 | 05:36 PM
4dooritr's Avatar
Yeah thats what I was saying to this exhaust shop guy today. he said he wont do it unless its center/center.. I guess I will be buying my own welder and doing the fab work my self.. the muffler its self is 25" long tip to tip.. its too long for your average coupe but since the 4 door has a extra 4" to work with.. I am going to stop by another exhaust shop tomorrow to see if they will do it.
Old Dec 2, 2008 | 11:07 PM
Slain's Avatar
its one of the quietest mufflers i've ever run. sounds similar to the stock itr or rsr mufflers granted you have a cat and a resonator on this set up
Old Dec 3, 2008 | 06:23 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Super Turbo muffler = quiet? haha not the ones I've heard. Dynomax Ultraflow mufflers are more quiet than Super Turbos.
Old Dec 3, 2008 | 11:04 AM
4dooritr's Avatar
Yeah I run either a T1R resonated test pipe or a 2.5" cat. and a resonator
I'm glad it will be quiet.
Old Dec 3, 2008 | 12:26 PM
Slain's Avatar
the super turbo muffler is chambered and i believe the ultraflow is straight through..
there are a couple of threads on HT about them
https://honda-tech.com/forums/showth...uffler+dynomax
https://honda-tech.com/forums/showth...+dynomax+turbo
https://honda-tech.com/forums/showth...ax+super+turbo
jdmilf
Jun 15, 2005 02:36 PM
hazard_one
May 20, 2005 08:33 AM
pdiggitydogg
Nov 16, 2004 09:09 PM
Sam268
Jul 3, 2003 05:44 AM
