91 B16A sloppy shifter
Old Jun 1, 2004 | 07:32 PM
jonezey00's Avatar
Default 91 B16A sloppy shifter
like the title says... I have a 91 Rs with 121k on it... It's on it's second trans, and now the shifter has become very very sloppy (moves a lot from left to right without accoplishing anything)... my question is... can I just get a short shifter for it... or is the problem in the trans itself... I'm sure somebody has had this problem... so a little help is appreciated...
thanks
Old Jun 1, 2004 | 07:40 PM
D Grade's Avatar
Default Re: 91 B16A sloppy shifter (jonezey00)
Sounds like something associated the shifter. Try jacking up the car and taking a gander around the shifter from underneath. I believe there is a rubber sleeve/gasket the shifter sits in, check around that area and tug around a bit. Also look to see if the bolt holding the shifter in place is tight. It may also be wise to check the shift linkage.
Tug'n around should give you a good idea where its loose.
krazykay5487
Jan 7, 2007 03:50 AM
gameknb
Jun 11, 2005 07:32 AM
STHPERFORMANCE
Jul 6, 2003 07:28 PM
hitekper4mance
Dec 27, 2002 04:28 PM
LD_EGSICK
Jun 25, 2002 12:31 PM
