vaccum source for wastegate?
Wastegate doesnt need a vacuum source...only needs a source that shows it boost.
T it into any vacuum source from the Intake Manifold (because they will see boost as well) or hook it up to the nipple on your turbo.
i know but there is one side that says BOOST and one side that says Vaccum, people say i need the vaccum part hooked up when i use a boost controller
you only need to use that other port if you are running an electronic boost controller. just the boost line will be fine if you are letting the spring decide or are using a manual boost controller
oh whoops...in that case what WG are you using? i'm assuming a TiAL...Top port goes to your AVC-R silenoid (sp?) and the side port goes to your compressor housing, or any other vac source (brake booster, FPR, etc.)
it might see boost pressure a little less than what it will see closer to the manifold, but people don't realize that with a MBC, you can just adjust it to compensate for the difference in boost readings........
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mademan2723 »</TD></TR><TR><TD CLASS="quote">T into the brake booster line which is the huge vacum line coming out from the drivers side firewall into the IM.</TD></TR></TABLE>
just what I did. use the side port, not the top one.
Silva Bullit DC4
Jan 17, 2008 02:06 PM
