Manual boost controller
Old May 24, 2009 | 07:29 PM
2ndchirp's Avatar
Default Manual boost controller
Just curious the instructions that came with my boost controller says to run a line from the waste gate to the boost controller and from the boost controller to the intake manifold.... does this sound accurate... I thought the vacuum line going from the wastegate would go to the turbo but my turbo (t3/t4) dont got a nipple for vacuum
Old May 24, 2009 | 07:33 PM
TheShodan's Avatar
Moderator
Default Re: Manual boost controller
Yes. you can do that from the better vacuum source. The instructions don't account for a line to the turbo compressor housing. The Intake manifold is a better source, but it is up to you.
Old May 24, 2009 | 07:42 PM
2ndchirp's Avatar
im confused Because the turbo does not have a place for a vacuum line .....the boost controller has 2 ports one line will go to the waster gate and the other to the intake manifold.... i installed a boost gauge already and ill be installling the boost controller this week
Old May 24, 2009 | 07:48 PM
TheShodan's Avatar
Moderator
Just use the intake manifold and top port of the wastegate. ignore the turbocharger boost source.
Old May 24, 2009 | 07:52 PM
2ndchirp's Avatar
ok thank you... I have a skunk2 manifold and there is a spare port on there...and i guess i found a use for it now
Old May 24, 2009 | 08:14 PM
beyondstock's Avatar
yes, most manufactors say you can T off the FPR but I always recommend trying to find a different source of vac. if you can. Any place is fine but use brake booster and fpr as a last resort...
skaraider
Jun 6, 2012 03:26 AM
importboi22
May 20, 2004 04:43 AM
99silverbullet
Jan 3, 2004 06:28 PM
redhatchb18
Oct 7, 2003 02:26 PM
It's*BOLO!!
Apr 10, 2003 07:54 PM
