Mysterious (back of the block) oil leak Maybe from turbo....
Old Apr 21, 2004 | 03:55 PM
not2slo128's Avatar
Default Mysterious (back of the block) oil leak Maybe from turbo....
i have a turbo 95 gsr. I installed the kit myself about 2 months ago but have had an oil leak ever since. I changed the oil pan gasket...that wasn't it. I looked at the oil return line....no leaks....the oil feed line by the back of the block where it goes into the brass fitting....no leaks.
After driving the car hard, if I jack it up, the bottom of the oil pan is wet with oil as well as the sway bar (behind it) and so is the A/C line running vertically (right near the turbo). There is also a drop or two of oil on the bottom of the turbo itself where the center section meets the compressor... I m totally clueless...
My last guess would be that the oil is coming out of the turbo itself. I disconnected my piping and discovered a considerable amount of oil inside the pipe. My oil return line might not be as free flowing as possible. I know that the oil return is gravity fed so it might be backing up the oil...but Im not blowing out any smoke
I DONT KNOW?!?!?!?
PLEASE tell me what you think
Old Sep 21, 2005 | 09:23 PM
herde1724's Avatar
Default Re: Mysterious (back of the block) oil leak Maybe from turbo.... (not2slo128)
if you've got a lot of oil in the charge pipes sounds like ur return is a lil restrictive and caused a back up in the turbo over time this blows out the seals in the turbo
Blue-EM1
Nov 20, 2005 07:23 AM
Snafu-Si
Jan 22, 2005 10:21 AM
15psi of fun
Feb 4, 2003 10:17 PM
Weston
Jan 26, 2003 01:37 AM
B20-T
Jul 29, 2002 06:01 AM
