Problem
Old Apr 21, 2004 | 09:05 AM
Tee Jay's Avatar
Default Problem
In my 96 CX the stock gauge was swapped out for an EX gauge. The problem I have is that the SRS light is on out of no where. I unplug the battery, positive and negative for 5 mins. or so and its still on. Any idea on what could be the problem? No accidents have occured either.
Old Apr 21, 2004 | 09:06 AM
skip.two's Avatar
Default Re: Problem (Green_Machine)
is your airbag plugged in?
Old Apr 21, 2004 | 09:11 AM
Tee Jay's Avatar
Default Re: Problem (jL iLLuZiOnz 9)
How do I check that. The light just came on yesterday after I purchased the car about 1 month ago.
Old Apr 21, 2004 | 09:18 AM
t00jayzee's Avatar
Pull the cluster out, and double check to see all the conection are still there.. IF they are check the fuses, then the wiring for the airbags. (just follow the wiring from the airbag to the main box.)
Old Apr 21, 2004 | 09:36 AM
Tee Jay's Avatar
Default Re: Problem (t00jayzee)
Dang this is gonna suck since I didn't do the gauge swap.
Old Apr 21, 2004 | 09:37 AM
deeksmooth's Avatar
well since it was just a gauge swap from a CX to EX, no wiring changes were neccessary. i'd check the plugs to the underside of the seats and all the SRS connections/fuses. then do the reset, check out the link below for how to reset the SRS.
https://honda-tech.com/zerothread?id=264288
Old Apr 21, 2004 | 09:45 AM
Tee Jay's Avatar
Default Re: Problem (citrEK)
Thanks
Old Apr 21, 2004 | 10:43 AM
Tee Jay's Avatar
That MES plug is hard as **** to pull out so I gave up do it when its cooler outside!
DoWnfall
Mar 31, 2008 08:18 PM
crazyemokid
Dec 8, 2006 10:23 AM
djeclipzjv
Jun 16, 2006 11:11 AM
97_delsol_Vtec
Feb 4, 2006 01:10 AM
cpforyou
Nov 10, 2003 07:44 AM
