gauge cluster light doesn't work?? help me!
i think i was messing with my wires..isntalling a boost gauge light...and so im guess one of my fuses blew out..theres nothing wrong with the bulb because when i autostart my car...the gauge blinks up and so does my side markers and corners...when i start my car and drive off...the cluster light turns off..and so does my corner and side markers...checked the fuse..nothing wrong but imma check again tomorrow morning...could anyone help me out? i would greatly appreciate it
Re: gauge cluster light doesn't work?? help me! (97_delsol_Vtec)
I hate electrical wiring problems...
Well if you did all the wiring yourself check the wires coming from the boost gauge and make sure they arent touching anywhere causing a short, check make sure battery cables are tight, and also check all of your ground wires to make sure they aren't loose and grounded properly.
I dont think it's a blown fuse otherwise the lights wouldn't even come on at all.
Hope this helps and you figure the problem out dude
cpforyou
11-10-2003 07:44 AM
