16x7.5 wheels?
Old Apr 14, 2004 | 04:41 PM
.RJ's Avatar
.RJ
Default 16x7.5 wheels?
Came across as set of 16x7.5 +32 offset Kosei K1 wheels listed on another forum.
What kind of clearance issues would I run into? I'm kind of curious to give 215/45 falkens a shot. Pretty good price on the wheels, and i've got enough 15" tires to keep me busy for the rest of the year but its something i'd like to try.
RJ
Old Apr 14, 2004 | 04:44 PM
ZygSpeed's Avatar
Default Re: 16x7.5 wheels? (.RJ)
https://honda-tech.com/zerosearch
Old Apr 14, 2004 | 04:48 PM
.RJ's Avatar
.RJ
Default Re: 16x7.5 wheels? (zygspeed)
Your search for 16x7.5 returned no results.
Please try different search criteria or a different data set.
Old Apr 14, 2004 | 04:51 PM
.RJ's Avatar
.RJ
Hrmph. Zerosearch is acting funny.
Old Apr 14, 2004 | 05:00 PM
ZygSpeed's Avatar
Your search for Kosei + offset returned 72 results.
Old Apr 14, 2004 | 05:04 PM
RTW DC2R's Avatar
buy them, let me test them out, and Ill report back to you.
arent 7.5" wheels a problem in 15" sizes? I would think a 32 offset would rub the fenders, no?
.RJ's Avatar
.RJ
https://honda-tech.com/zerothread?id=746820
https://honda-tech.com/zerothread?id=525452
https://honda-tech.com/zerothread?id=639242
https://honda-tech.com/zerothread?id=120496
https://honda-tech.com/zerothread?id=105147
With 16*7.5" Advans you won't need any fender work with the stock suspension. This is because the Advans are +45 offset
Hrmph. Thats an extra 1/2" towards the fenders with those K1's....
https://honda-tech.com/zerothread?id=92809
16x7 TE37, 43mm offset, with tires 33 lbs (215/45 Azenis), it does rub
Mugen MF-10's... +43mm offset... 215-45/16 Falken Azenis... stock suspension
slight rub on inside with full lock, just nips the plastic fenderwell liner on the inside.
At least they wont rub in front!
https://honda-tech.com/zerothread?id=53742
Ok, I have a set of spoons 16 x 7 (+45 Offset) and I just put on a set of 215 45-16's and they just BARELY fit, and I also shaved about half of the width of the lip of the fender (sorry about construction of sentence..didn't know how else to word it)
Old Apr 14, 2004 | 05:05 PM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed &raquo;</TD></TR><TR><TD CLASS="quote">Your search for Kosei + offset returned 72 results.</TD></TR></TABLE>
Used a different search string
.RJ's Avatar
.RJ
I dont think these are going to fit in the reer
Old Apr 14, 2004 | 05:36 PM
George Knighton's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">I dont think these are going to fit in the reer </TD></TR></TABLE>
I don't think they're going to work, either.
OEM 16's are +50, and Spoon 16x7 are +45.
With 15x7 Kosei +38 and Toyo RA 205's, we still had to adjust the left rear fender.
I think you're safer trying different wheels.
Old Apr 14, 2004 | 05:37 PM
.RJ's Avatar
.RJ
Default Re: 16x7.5 wheels? (George Knighton)
*crawls back into pile of 15" tires*
Old Apr 14, 2004 | 05:49 PM
ZygSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">*crawls back into pile of 15" tires* </TD></TR></TABLE>
Hey RJ, I've got a set of JDM 16's w/Azenis ... with your name on them!
The Infamous Speedpak/Yoshi rattlecan black specials (w/centercaps).
Old Apr 14, 2004 | 05:51 PM
.RJ's Avatar
.RJ
Dammit
Maybe later this year.
Old Apr 14, 2004 | 06:04 PM
Type-R Yo!'s Avatar
New User
I'm running 16*7.5 +45 offset Advan rg's with 215/45-16 azenis on the R. The car has buddy club suspension on it. The gap between the tire and the fender is about one finger at the most (corner weight ). The only rub is in the front but only at full lock.
.RJ's Avatar
.RJ
Default Re: 16x7.5 wheels? (Type-R Yo!)
Sounds like that would be the best offset to use.
Maybe later i'll look into it.
Old Apr 14, 2004 | 06:52 PM
StageOne's Avatar
I've run the 215/45/16 Azenis on the track and autocross. I really did not like them. The gearing was to tall compared to the 205/50/15s. It is a significant difference IMO and I would not not switch back unless I had a higher final drive and/or much more power.
Example, all over mid-ohio, I felt like I was in the wrong gear and I had to shift too often, even into 2nd for the keyhole and carousel. With the 15s, I could run the course in 3rd and 4th and I picked up some time. I know its course dependent, but the 3 tracks I ran on, the 15s were the better choice.
Old Apr 14, 2004 | 09:06 PM
Black R's Avatar
25 Year Member
.....15x7.5 +40's here. They are perfect (although on a slammed y0 itr, they rub the plastics up front a little bit).
kloscivicsi
Honda Civic (2006 - 2015)
Jul 10, 2008 11:58 AM
DisturbedK24
Jun 4, 2008 07:27 PM
Dr. Phil
Jun 23, 2007 12:56 PM
dyg2001
11
Jun 12, 2003 01:53 PM
