What size injectors for my turbo setup??
Old Mar 31, 2004 | 11:49 AM
xtremeness101's Avatar
Default What size injectors for my turbo setup??
Here is my setup im putting together:
b18c1
stock bottom
stock head
Garret t3 60 trim a/r .48
tial wastegate
tial 50mm BOV
spearco intercooler
2.5" downpipe
3" catback
hondata with boost option and datalogging
I will be running 8-9 psi daily driven.
My question is; What kind of injectors and what size what you reccomend me getting. What else would i need in regards to my fuel system. Fuel pump? Fuel rail? Fuel Pressure regulator? What sizes and brands do you recommend?
Thanks in advance for any help you guys can give me.
Old Mar 31, 2004 | 11:59 AM
MaxSterling's Avatar
Default Re: What size injectors for my turbo setup?? (xtremeness101)
440cc, stock fpr 1:1.
Old Mar 31, 2004 | 12:19 PM
Default Re: What size injectors for my turbo setup?? (MaxSterling)
what should i get 440 rc injectors? or is there a different kind i should get?
also what does saturated injectors mean?
Old Mar 31, 2004 | 12:33 PM
99B16Si's Avatar
saturated dont require a resistor box. id go with 550's just to leave yourself with some room later on down the road.
Old Mar 31, 2004 | 12:36 PM
VisualAutoMotoring's Avatar
Default Re: (99B16Si)
If u plan on boostin more later, then go with
550cc now
fuel rail
aeromotive FPR
Walbro 255
remember fuel is very important...better to have more and run a lil rich then u can always tweak it down
Old Mar 31, 2004 | 12:38 PM
TravSi's Avatar
i would go with 550's (RC), 255 pump (Walbro), and adjustable fpr....Since yur running a Hondata it will run good with 550's....
Old Mar 31, 2004 | 02:23 PM
civic97dx's Avatar
Default Re: What size injectors for my turbo setup?? (TravSi)
go with 550cc's
I'm going with a similar set-up and my tuner recommend thoses. Leaves more room for upgrades
Old Mar 31, 2004 | 02:31 PM
ladysman's Avatar
Default Re: What size injectors for my turbo setup?? (civic97dx)
I agree with the 550cc recommendation.
Old Mar 31, 2004 | 07:21 PM
Default Re: What size injectors for my turbo setup?? (ladysman)
Thanks, im going to go with the 550s
Old Mar 31, 2004 | 07:23 PM
Timmay's Avatar
dsm's would work good for under 10psi
Old Mar 31, 2004 | 07:32 PM
D3LSLO's Avatar
Default Re: What size injectors for my turbo setup?? (Timmay)
the stock fuel rail will handle quite a bit, up to 300-350 i believe, someone correct me, but based on ur set up i think that will be fine for u, ma7ybe get a fpr and do go with those 550s.
golf-mk3
Oct 7, 2010 05:27 AM
B6teen
Jan 8, 2008 07:46 PM
prelude1911
May 20, 2005 08:37 PM
buda18
Nov 10, 2003 06:46 PM
Hybridhonda10
Apr 3, 2002 07:39 AM
