what size injectors..turbo gsr
stock gsr motor
revhard kit...walbro 255lph fuel pump,fuel rail,FPR(altho i heard stock ones are better)
running 8psi
goal of 300 whp
will 550cc be good for this setup?
thanks
running 8psi
goal of 300 whp
thanks
Re: what size injectors..turbo gsr (ben@importparts.com)
ok so with the fuel pump will that not increase fuel pressure therefore flowing more fuel out of the injectors right? even with that...ill be using the injectors to max?
so the injectors still wont be able to send out enough fuel?
