CYP Sensor
Old Oct 24, 2001 | 11:51 AM
showngo92's Avatar
New User
Default CYP Sensor
My distributor went out on 92 Prelude S. I replaced the distributor and the ECU keeps throwing the 09 code (CYP Sensor). The light went off before I replaced the distributor and when I got the new one in and the light kept going off I thought, what the ****!
I got the code from the ECU again and it was once again the 09 code for the CYP sensor. The CYP Sensor is in the distributor correct? I pulled the clock fuse to reset the ECU and it still goess off and I even disconnected the battery to get it to go off but it hasnt yet. Do you think the distributor I bought could have been bad? It was a reman!
Thanks for any help!
--Bill
Old Oct 24, 2001 | 11:53 AM
Jared's Avatar
Default Re: CYP Sensor (showngo92)
You have two possibilities. Either you have another bad distributor, or you have a wiring problem between your ECM and the distributor.
Old Oct 24, 2001 | 11:58 AM
showngo92's Avatar
New User
Default Re: CYP Sensor (Jared)
Well I dont think any of the wiring is bad, since the light only started going off when the distributor went out. I think I shoudl just get a new distributor, remans suck big time!
I pulled the clock fuse and even disconnected the battery that should clear the ECU of any codes and since it still throws the code it is still be sent to the ECU, correct? I just dont want to get a new distributor when the code is just being stored in the ECU and can be cleared out.
Thanks Again,
--Bill
Old Oct 25, 2001 | 01:03 AM
sgT's Avatar
sgT
You shouldnt even have to reset the ECU. Cycling the power(aka turning the key
off and on again) should reset it since it pretty much resets itself when u do that.
aviator.sm
Engine Management and Tuning
Jul 26, 2018 12:10 PM
Ej8 d16
Jan 23, 2015 01:37 PM
CivicHatchback14
Jul 14, 2004 12:00 PM
sc00te12d00d
Dec 11, 2003 09:01 AM
Slatelude
Oct 13, 2003 05:26 PM
