ECU code #9
Old Jul 12, 2004 | 11:36 AM
CivicHatchback14's Avatar
Default ECU code #9
I am throwing code 9........ i think. It is a 1992 ecu.... can someone please help me with what that is. thanks
Old Jul 12, 2004 | 11:47 AM
JimBlake's Avatar
Default Re: ECU code #9 (CivicHatchback14)
You couldn't have searched very far, there's a sticky thread up on the very top of this BB.
9 = CYP sensor
That's in the distributor. You might want to check for loose wiring where the harness plugs into the distributor, then check for loose connections inside the distributor. I think(?) you have to buy the distributor to get that sensor.
Old Jul 13, 2004 | 01:09 AM
Default Re: ECU code #9 (JimBlake)
ya, thanks. i have been reading on it, but haven't got much besides it could be the dist.
Old Jul 13, 2004 | 05:33 AM
JimBlake's Avatar
There's 2 sensors (CYP & TDC) down inside the distributor, you have to take out the coil & ignitor to get at them. If you see a bunch of rusty-colored dust down there, maybe you can clean it up & be OK for a little while, while you order a new distributor. If you find broken pieces of stuff, you need a new one right now. If you're lucky, you'll find a loose wire (inside or outside the distributor) that you can fix.
Old Jul 14, 2004 | 12:04 AM
well, i changed my cap and rotor and everything looked nice. But when i slid the rotr onto the little nub thing i noticed it wa sextremely loose. i started the car back up and there was a very loud gargaling noise coming from the dist. I didn't drive it to work. It was far to scary. it didn't sound good. so now i am going to pick up a distributer from a friend tomarrow. thanks for all the help.
Old Jul 14, 2004 | 04:09 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicHatchback14 &raquo;</TD></TR><TR><TD CLASS="quote">... there was a very loud gargaling noise coming from the dist...</TD></TR></TABLE>that's usually NOT a good thing...
But was the noise there before? Did you get the wrong rotor so it didn't fit correctly? Code 9 isn't the cap & rotor, those sensors are down inside the distributor below all the other stuff.
Old Jul 14, 2004 | 12:00 PM
the noise started coming right after my CEL came on. So i thought my rotor was rubing on something, so i looked at it and it was messsed up. So i bought a new one. the problem was still there. I took my distributor off today and replaced it. (good thing my friend had one laying around) The part that goes into the cam was totally fried. Like the baring was spinning like dog ****. i don't understand what caused this, but im glad it is now fixed. thanks for all the help Jim!
Migs19
Sep 7, 2016 12:32 PM
Ej8 d16
Jan 23, 2015 01:37 PM
jdmeg1075
May 22, 2008 03:52 PM
sc00te12d00d
Dec 11, 2003 09:01 AM
Slatelude
Oct 13, 2003 05:26 PM
