runnign 9 psi what should i have?
Old Mar 27, 2004 | 04:50 PM
blackccoupe's Avatar
Default runnign 9 psi what should i have?
hey guys i'm running 9 psi with a fmu b m fpr do i need anything else
Old Mar 27, 2004 | 04:55 PM
b16ahybrid's Avatar
Default Re: runnign 9 psi what should i have? (blackccoupe)
Yeah you need to tell us your set-up. Your engine? etc....
Give vague questions get vague answers
Old Mar 27, 2004 | 05:36 PM
Default Re: runnign 9 psi what should i have? (b16ahybrid)
i have a d16z6 1st gen talon turbo fpr fmu exhaust front mount and running 9 psi
Old Mar 27, 2004 | 05:40 PM
ITSTOCK's Avatar
what year car? personally i wouldnt run an fmu or hack agai even if it was only 5psi.
Old Mar 27, 2004 | 06:16 PM
b16ahybrid's Avatar
Stock injectors?
If so, your probably pushing your luck a little.
I wouldn't recomend runing more then about 5psi on stock injectors and and if you upgrade to 310cc injectors your can get away with about 8psi.
Using a fmu is a crude way of tuning, it's not precise in any way. I would recomend getting some larger injectors and a vafc that way you can dial in the afr a little better.
I ran a fmu/310cc injectors and sfc it worked ok for my set-up. I just switched to hondata and picked up about 25whp just by tuning.
Old Mar 27, 2004 | 07:11 PM
Ls-Rturbo's Avatar
a turbo would help
Old Mar 28, 2004 | 12:14 PM
Default Re: runnign 9 psi what should i have? (bl18t)
so running 9 is not a good thing then i will mess with it then
Old Mar 28, 2004 | 12:25 PM
also my car is a 94 should i only run injectors or injectors with the hack ?
laakea
Apr 3, 2006 07:13 PM
thruvines87
Dec 5, 2004 10:28 PM
93turbo16
Aug 19, 2004 09:22 PM
freeplay
Dec 1, 2002 09:41 AM
Giuseppe
Oct 10, 2001 09:23 PM
