runnign 9 psi what should i have?
Re: runnign 9 psi what should i have? (blackccoupe)
Stock injectors?
If so, your probably pushing your luck a little.
I wouldn't recomend runing more then about 5psi on stock injectors and and if you upgrade to 310cc injectors your can get away with about 8psi.
Using a fmu is a crude way of tuning, it's not precise in any way. I would recomend getting some larger injectors and a vafc that way you can dial in the afr a little better.
I ran a fmu/310cc injectors and sfc it worked ok for my set-up. I just switched to hondata and picked up about 25whp just by tuning.
