New to turbo --> stupid wastegate spring question
With the spring rates. Is that rate the amount of boost i will be running at? Also, with the same spring, how far can you raise and drop boost from what it is rated at?
Re: New to turbo --> stupid wastegate spring question (WhiteLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteLude »</TD></TR><TR><TD CLASS="quote">With the spring rates. Is that rate the amount of boost i will be running at? Also, with the same spring, how far can you raise and drop boost from what it is rated at?</TD></TR></TABLE>
wastegates allows gas at a predetermined psi once reached to be released. its a way to somewhat regulate boost but not control it, thats where a boost controller comes into play.
yes... the spring rate is most always the psi it will run/release at.
yes you can go above your spring somewhat, usually double your spring rate is the max.
no you can not go lower than your spring rate.
Short Round
11-12-2003 10:16 PM
