EX tranny swapped Help Grinding!
Old Mar 24, 2004 | 11:57 PM
Jwcivic's Avatar
Default EX tranny swapped But Grinds! Tech Help pls?
I have 96 DX
My DX ISB was shot, so I got an EX tranny put in. It was from a 99, but cant tell if its good or not. anyway, I drive it and when I go from 2nd - 3rd, it grinds. 3rd to 4th and back is ok. if I go 5th to 4th it grinds sometimes too. So it looks like it has problems going into the 3 and 4 from 1,2, and 5. I was told its because I have a short shifter too. I think its the syncros for 3 and 4. I can shift into 3rd with no grind if I let the RPMs fall to idle then shift. At lower RPMs I can also pull out with no clutch. Whats the problem? I don't want to fix my DX and go back, I like the EX now, but of course I will if I have to. How bad are the gears now that Ive grind several times since I put it in?
thanks for the help everyone
Old Mar 25, 2004 | 01:40 AM
1.8turbolsvtec's Avatar
Default Re: EX tranny swapped But Grinds! Tech Help pls? (Jwcivic)
what oil did you used
Old Mar 25, 2004 | 03:33 AM
stackz's Avatar
at the jetties fishin'
Community Builder
are you racing when you do this shifting and get grinding or normal driving?
you might not have the linkage set up right so it might be binding. if you didn't get the input shaft centered right that will also cause a lot of binding.
Old Mar 25, 2004 | 03:57 AM
sohc_boy's Avatar
Default Re: EX tranny swapped But Grinds! Tech Help pls? (stackz)
did u chk the oil level in the tranny?
Old Mar 25, 2004 | 04:29 AM
BauleyCivic's Avatar
Risky Business
Default Re: EX tranny swapped But Grinds! Tech Help pls? (sohc_boy)
Shoulda bought these
Old Mar 25, 2004 | 04:45 AM
itsJDMyo's Avatar
Default Re: EX tranny swapped But Grinds! Tech Help pls? (BauleyCivic)
ok, i know those 2 bottles are oil, but what's the other thing? haha
Old Mar 25, 2004 | 05:24 AM
skip.two's Avatar
GM Synchromesh FM
yea what is that other thing?
Old Mar 25, 2004 | 05:42 AM
tilt's Avatar
Default Re: EX tranny swapped But Grinds! Tech Help pls? (jL iLLuZiOnz 9)
looks like an input shaft bearing
Old Mar 25, 2004 | 08:20 AM
Jwcivic's Avatar
I dunno what oil they used, but I highly doubt the make of the tranny fluid would cause this. all the fluids were changed, this happens on normal driving. Sometimes when I get it in 3rd and release clutch pedal, it grinds and pops out. For some reason I want the problem to be something other than what the shop told me; that it was because of my short shifter. I really like my short shifter and don't want to get rid of it, unless I get the fastline shifter. If its the syncros, GM syncro mesh will fix the problem? is it that easy?
Old Mar 25, 2004 | 10:35 AM
Jwcivic's Avatar
what happens if the syncros are bad? can anyone help me diag. the prob?
Old Mar 25, 2004 | 10:40 AM
Marauder's Avatar
A short shifter doesn't cause gears to grind.
Must be the synchros, if the synchromesh fluid doesn't help, you'll need new synchros in the tranny.
I wouldn't trust buying used tranny's anymore. I bought one, and the guy said it only had a slight 2 to 3 grind. Split the cases and so many parts were fried! SO I bought a professionally built tranny instead with a two year warranty!
Old Mar 25, 2004 | 10:43 AM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">Shoulda bought these
Just bought some of that for my D16Y8, but I bought 3 quarts - do I only need 2?
Old Mar 25, 2004 | 10:45 AM
MPsquad's Avatar
Sounds like your have a problem on your hands. If there was a slight problem in every gear the Oil might help, but the different gears seems like the synchros. To fix those you have to open the tranny and replace. Sorry. I hate to say it.
Old Mar 25, 2004 | 10:51 AM
greebler's Avatar
Default Re: (MaconPerformance)
I have the same problem, its the 3rd gear syncro. I got some syncro mesh a few months ago and will eventually try that.
Old Mar 25, 2004 | 11:04 AM
pdiggitydogg's Avatar
typical honda 3rd gear synchros
Old Mar 25, 2004 | 12:05 PM
snatch13's Avatar
Default Re: (pdiggitydogg)
hell yea... has anyone had their synchros replaced?? i might have to on my car and a friend told me it would cost about 600 bucks and thats not including labor since he would do it himself... does this sound right?
Old Mar 25, 2004 | 12:13 PM
a1320honda's Avatar
Default Re: (snatch13)
there has been some threads on the gm synchromesh oil if you look. i had a slight 1-2 grind and used the gm stuff (for $11.99 a quart) and all is well in tranny land right now. no grinds whatsoever and feels like a hot knife cutting through butter. i always say to try the cheapest option first, in this case replacing fluid with this stuff is worth a try.
Joey Mitchell
Apr 29, 2019 07:50 AM
EK45VTi
16
Oct 31, 2004 03:05 AM
b18bme
10
Aug 19, 2004 07:00 PM
d15b7racer
Sep 24, 2003 01:05 PM
Unjockable
10
Dec 12, 2001 04:21 PM
