My civic won't move
Old Mar 21, 2004 | 08:06 AM
philgood's Avatar
Default My civic won't move
Hi guys!
I have a Civic EXR. A couple of days ago I was shifting into the first gear and I heard a small pop sound.
Then the vehicle wouldn't move. All the gears engage but the vehicle wouldnt move back or forward.
Does anybody have an idea what might be the problem?
Is this a Transmission problem?
Transmision output shaft and Front wheels?
I recently did some work on control arms.
Thanks.
Old Mar 21, 2004 | 08:07 AM
Clayton's Avatar
H-T Administrator
25 Year Member
Default Re: My civic won't move (philgood)
axles? Clutch, trans, I'd check in that order myself, but I hate trannies and clutches.
Clayton
Old Mar 21, 2004 | 08:11 AM
MrBui's Avatar
axle probably popped out
Old Mar 21, 2004 | 08:30 AM
miahmouse's Avatar
any grinding noise when trying to move?
first, look to see if the axles are intact.
Old Mar 21, 2004 | 08:35 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philgood &raquo;</TD></TR><TR><TD CLASS="quote">I have a Civic EXR. A couple of days ago I was shifting into the first gear and I heard a small pop sound.
What sort of work were you doing? Did you remove the axles?
You may have had an axle pop out of place. Check your axles, particularly where they fit into the transmission.
If not, I'd say it is a clutch problem.
Old Mar 21, 2004 | 07:59 PM
Mike Ockhurts's Avatar
Default Re: My civic won't move (Targa250R)
calipers could be rubbing against your rims? juss a guess sinces it happened to me once
Old Mar 21, 2004 | 08:17 PM
JSPECEX's Avatar
Default Re: My civic won't move (lilredridinghood)
its got to be the axle just put it in drive and look if half of the axle moves becuase it could be broke in the bootand you won't even see it unless it is moving
Old Mar 21, 2004 | 08:52 PM
JDMlyfestyle's Avatar
Definately gotta be an axle
Old Mar 22, 2004 | 08:45 AM
makaveli_0000's Avatar
Not too familiar with front wheel drives but I can bet my money that it is neither your tranny nor your clutch. What ever connects the tranny output shaft to the front wheels (axle ?) is out of place or broken.
If you recently did some work on the control arms and had to take out the axles, then I'd suspect your axles were not tightened to spec.
If your tranny was heading south, you'll get symptoms such as sticky shifting, grinding, slipping and others. If your clutch was heading south, you'll find it hard to engage gears, gears slip or grind etc, similar to the tranny heading south.
What ever connect your tranny output shaft tou your front wheels is the culprint. If it is the axles, check them. If this was a rear wheel drive, I'll tell you immediately that is is your driveshaft.
Good Luck.
Old Mar 22, 2004 | 08:59 AM
B18C4-T's Avatar
Default Re: My civic won't move (makaveli_0000)
I was driving and heard a pop (well my wife did.) When I got off the freeway I couldn't get it out of gear. If the car was off it'd go through the gears, but not when it was running. When I tore it down I found out that I'd blown my pilot bushing up. Cheap part, just a pain to replace.
Old Mar 23, 2004 | 06:35 PM
philgood's Avatar
Thanks guys!
100% correct diagnosis....
Axles popped out.
Thanks for your quick replies!
doubleoazn03
18
Apr 26, 2015 09:22 PM
darkwater_ghost
Transmission & Drivetrain
Jan 3, 2013 11:31 AM
darkwater_ghost
Jan 3, 2013 10:52 AM
rasinhell
12
Feb 21, 2005 09:36 PM
Apollo
May 4, 2004 05:14 PM
