When buying an O2 sensor....
Old Mar 15, 2004 | 06:26 PM
2 point 0's Avatar
Default When buying an O2 sensor....
how can you tell if it's sencondary or primary?
Old Mar 15, 2004 | 06:41 PM
Smith Wise's Avatar
Default Re: When buying an O2 sensor.... (2 point 0)
some say the interchangeable.... but why would Honda charge so much more for the secondary?
I don't think there is really any definite way to tell unless you get an unopened package from honda with the secondary o2 part number on it....
Old Mar 15, 2004 | 06:45 PM
Ricey McRicerton's Avatar
Default Re: When buying an O2 sensor.... (Jswpstdoff)
EDIT: I was not right...damn that 10%. I guess that's what happen when you don't run an OEM primary 02 sensor and just run off of a wideband's narrowband output.
Modified by Ricey McRicerton at 10:56 PM 3/15/2004
Old Mar 15, 2004 | 06:55 PM
BI8B's Avatar
Default Re: When buying an O2 sensor.... (Ricey McRicerton)
both plugs are the same. can anyone confirm that they're interchangeable?
Old Mar 15, 2004 | 06:56 PM
Smith Wise's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">One has a male plug, the other has a female. I'm about 90% sure on this one.</TD></TR></TABLE>
but they will still fit either plug.... go figure... how do you tell the plug apart....
Old Mar 15, 2004 | 09:02 PM
2 point 0's Avatar
can anyone confirm?
Old Mar 16, 2004 | 12:01 AM
2 point 0's Avatar
anyone?
Old Mar 16, 2004 | 04:32 AM
EE_Chris's Avatar
99 Civic hatch - D16Y7
My O2 sensors are interchangeable.
Old Mar 16, 2004 | 11:15 AM
2 point 0's Avatar
Default Re: When buying an O2 sensor.... (EE_Chris)
u positive right? thanks...
Old Mar 16, 2004 | 12:00 PM
96dc2's Avatar
They are both the same and are interchangeable! In some applications, there will be a blue grommet.
Modified by 96dc2 at 10:02 AM 3/17/2004
Old Mar 17, 2004 | 05:00 AM
EE_Chris's Avatar
As you can see, mine share the same physical connector....the heat shields and wiring lengths are different.
dorkjoey
19
Apr 30, 2008 09:44 PM
jDMJeRk
Oct 26, 2007 08:14 PM
Sprockets
Dec 13, 2005 11:32 AM
Blue-Civic-Hybrid
Dec 6, 2003 10:53 PM
99ls
May 21, 2003 09:17 PM
