VAFC tunning
Old Mar 13, 2004 | 06:30 PM
b16bdelsolsi's Avatar
Default VAFC tunning
alright i just installed my vafc and i was wondering what settings i should put everything at so i will be monitring alll the right readings. i have a 95 b16a swaped into my 94 delsol. stock internals intake header exaust. i dont want to lower the vtec to much because i heard you can hurt the motor. what are some of the other settings i canadjust to get some more power out of it.
Old Mar 14, 2004 | 12:18 AM
Syner-G-Racing LLC's Avatar
Default Re: VAFC tunning (b16bdelsolsi)
h-t members arent very setting friendly from what i have found out. i posted four different post trying to get everyone to compare their settings to better understand peoples techniques and theorys.
i have a B18c and you need to understand these settings may not work well for you but it can give you a foreground for your own.
v-tec
5000 lo>hi
4800 hi>lo
unmatched
lo>hi 10%
hi>lo -5%
throttle position
10% narr
50% wide
air corr
narr - lean out fuel a little before v-tec (hondas run rich) and start adding fuel at engagement and gradualy increase untill past factory engagement then lean out gradualy.
do the same for wide but be a little more aggressive. I will send you my actual settings at a later time. Its ok to try different settings, at the worst you engine light will come on for your map sensor if you shoot to much fuel, unless your running a turbo you dont have to worry about leaning it out to much.
red_ek_hatch
Apr 4, 2005 05:26 PM
98 blacksh
Feb 17, 2005 02:23 PM
tommy1
13
May 5, 2004 10:41 PM
SpoonfedDC2
Nov 20, 2002 08:34 AM
10seconds
Jul 8, 2002 01:34 PM
