Vafc Questions
Old Nov 18, 2002 | 06:20 PM
SpoonfedDC2's Avatar
Default Vafc Questions
Is the VAFC only able to move where vtec kicks in down to 5600rpm?
Old Nov 18, 2002 | 06:33 PM
integRated109's Avatar
Default Re: Vafc Questions (SpoonfedDC2)
im pretty sure you can set it as low as you want. make sure to drop the H-L(bottom RPM number) before you lower the L-H setting. if the bottom setting isnt right, it wont let you drop the top one.
Old Nov 20, 2002 | 08:16 AM
Default Re: Vafc Questions (integRated109)
thank you i figured it out 15 min after I asked the question.
Old Nov 20, 2002 | 08:34 AM
Hybrid 350GT's Avatar
Don't forget to adjust the fuel/air mixture when you move the V-Tec point. If you move it the fuel/air mixture will not be correct and will not give you optimal power. This should actually be done on a dyno.
gsrx
Nov 24, 2004 02:12 PM
jay-tec
Aug 22, 2004 06:34 AM
Dc2 Powered
Sep 5, 2003 02:40 AM
nicopod
Jun 20, 2003 03:21 PM
bartek_b
May 11, 2003 10:03 AM
