Injector questions, just need verification.
Old Oct 12, 2001 | 12:45 PM
Kalokohan's Avatar
New User
Default Injector questions, just need verification.
Okay, I have an OBDII engine in an OBDI car and I use an OBDI computer. In laymans terms: 93 hatch with 00 gsr engine and 95 gsr ecu. Do I need to get OBD I injectors or are the injectors that came with the engine which are OBDII fine? OBDII injectors will work using OBDI ecu's right? And vice versa? Either process works unless you use a pre OBD ecu right? Please verify!! THanx.
Old Oct 12, 2001 | 03:36 PM
Davep's Avatar
Default Re: Injector questions, just need verification. (Guardson3r3)
You will be fine with the injectors that you have.
honcrx91si
Aug 8, 2005 09:34 PM
transpar_nt
Jun 22, 2005 06:46 PM
Chris99SI
Jun 1, 2005 01:58 PM
See Are X
Oct 7, 2003 09:40 PM
Powered by Honda
Oct 12, 2001 10:07 PM
