Stock psi?
you're going to get mix informatio from everybody, why don't you test it out yourself? Do you have an air compressor at home? you can do test it with a boost gauge using the air compressor. Have the compressor turned up about 10 psi, find away to connect it to your wg and boost guage. If you don't have a compressor, get a bycicle pump.
