weird track numbers...need help
Old Jan 25, 2004 | 04:52 AM
mattcalica's Avatar
Default weird track numbers...need help
okay, i have a turbo b16, with a cable LS tranny, 205/45/16 tires...i just got back from tracks, and got these numbers...
60ft: 2.5 (bad, i know)
1/4 time: 15.4
1/4 speed: 94mph
now, thats what i dont understand, the trap speed...my friend with a type-r ran his car, and he had the same speed as me, but ran .7 seconds faster in the 1/4...what could be wrong here?
Old Jan 25, 2004 | 05:01 AM
Adriano's Avatar
Default Re: weird track numbers...need help (mattcalica)
you are spinning the tires too much probably. Usually when you get high trap speed and bad et, it's due to poor traction.
Old Jan 25, 2004 | 05:06 AM
mctonyb's Avatar
Default Re: weird track numbers...need help (brryder)
That trap isn't too bad, but for sure you have no traction down low to run a 60ft of 2.5 and a time of 15.4. Maybe let some pressure out of the tires, drop at a lower rpm, feather the clutch a bit, etc.
What's your setup?
Old Jan 25, 2004 | 08:54 AM
TravSi's Avatar
Default Re: weird track numbers...need help (mctonyb)
i would like to know the setup also? Those times seem really bad even the trap for a turbo b16 (i feel your pain with traction).....i ran a low 14 @ 103.95 with d16 on 6psi with a 2.4 60' on 185-60-14 dunlops...
Old Jan 25, 2004 | 02:27 PM
mattcalica's Avatar
okay, i got a stock b16, with gsr cams, i am using the hack...t3/t4 turbo, but i think thats where the problem is...i think i got a boost leak, so the car was only boosting from 6000-8000 rpm...i knew that was the problem of the low times, but i wanna know why the trap speed is so high for such a slow time.
Old Jan 25, 2004 | 02:38 PM
laughinxxx's Avatar
New User
Default Re: (mattcalica)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattcalica &raquo;</TD></TR><TR><TD CLASS="quote">but i wanna know why the trap speed is so high for such a slow time.</TD></TR></TABLE>
You need more practice driving. I've clicked off consecutive 103-104 mph traps and ended up with ET's ranging from 13.6-14.1 seconds. The problem is traction. I was running nitrous and only had khumo 712s on the car. If I had a 2.2 60' I was rewarded with a 13.6. If I had a 2.3 60' I had something around 14.0. Practice driving or get some drag radials and then practice driving. Go race on some backroads with a couple friends or go to the track. Just figure out how to exploit all of the power that you are making. You'll be in the 14's once you get that 60' down to a 2.3, and that's still a **** 60' time.
Old Jan 25, 2004 | 02:42 PM
mattcalica's Avatar
wow, didnt know the 60' made that big of a difference...this was my first time racing a 5 speed at the track, so i guess i got a lot of learning to do.
Old Jan 25, 2004 | 03:56 PM
nsxmatt's Avatar
94 mph is not high though. That is a high 14 second time with traction. Seeing as you had no traction your mph will be higher than normal for the time you run. I'd check all your problems before you head to the track again, your off a good 10mph over what you should run with a basic setup.
Old Jan 25, 2004 | 04:54 PM
GDM Z28's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattcalica &raquo;</TD></TR><TR><TD CLASS="quote">okay, i have a turbo b16, with a cable LS tranny, 205/45/16 tires...i just got back from tracks, and got these numbers...
1/4 time: 15.4
1/4 speed: 94mph
even with no traction you should put down better times than that. that is what i ran with just a ls swap. with a boosted ls i went 13.8@105 with no traction in 1st or second. try using better tires n see what happens
Old Jan 25, 2004 | 05:05 PM
CRX T-Si's Avatar
Default Re: weird track numbers...need help (civicflnum1)
Damn, I would not tell people that your driving a Turbo B16........
Thank goodness it's your first time.
One word "Practice" but remember not on the street.
Old Jan 25, 2004 | 05:49 PM
GDM Z28's Avatar
Default Re: weird track numbers...need help (CRX T-Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX T-Si &raquo;</TD></TR><TR><TD CLASS="quote">Damn, I would not tell people that your driving a Turbo B16........
One word "Practice" but remember not on the street.</TD></TR></TABLE>
even with his first time he should do better. my first time i went 13.8. do a compression check n see how ur motors doing
Old Jan 25, 2004 | 08:22 PM
mattcalica's Avatar
well, like i stated earlier, i got a boost leak as well...just need to find out where its at...the turbo only STARTED spooling at about 6000, and at 8000 it was only at 5 psi, i have a 7psi spring...anybody know a good site where i can get some slicks?
Old Jan 25, 2004 | 08:58 PM
b16ahybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattcalica &raquo;</TD></TR><TR><TD CLASS="quote">..the turbo only STARTED spooling at about 6000, and at 8000 it was only at 5 psi, i have a 7psi spring...?</TD></TR></TABLE>
Thats your problem........fix it.
Your basically runing a stock b16 in your car, but with a "little" kick up top. honestly i would be surprised if your set-up is making more then 160whp...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattcalica &raquo;</TD></TR><TR><TD CLASS="quote">...anybody know a good site where i can get some slicks?</TD></TR></TABLE>
I'd fix your boost problem first, then learn to drive your car before venturing into the world of traction...
Old Jan 26, 2004 | 03:38 AM
GDM Z28's Avatar
id invest in some upgraded axles before i bought slicks. if you go for slicks say bye bye clutch and sooner or later bye bye axles.
Old Jan 26, 2004 | 07:44 AM
Joseph Davis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattcalica &raquo;</TD></TR><TR><TD CLASS="quote">well, like i stated earlier, i got a boost leak as well...just need to find out where its at...the turbo only STARTED spooling at about 6000, and at 8000 it was only at 5 psi, i have a 7psi spring...anybody know a good site where i can get some slicks?</TD></TR></TABLE>
More important than your loss of power situation, a boost leak overspools yout turbo and it will start shitting out oil in short order. Tear the car apart, don't drive it.
kdawgy2k1
May 20, 2006 11:05 AM
jasb16A2aSIR2
Apr 19, 2005 05:24 PM
BLK99VTECR
Oct 28, 2003 09:53 PM
Kermit EK
Feb 23, 2003 01:41 PM
CRXGhettoGuru
Apr 8, 2002 02:03 PM
