Launching (b16)
Old Feb 20, 2003 | 09:58 PM
Kermit EK's Avatar
Default Launching (b16)
Is it better to launch high like 5k or lower with a b16?
Old Feb 20, 2003 | 10:05 PM
TeamTooQuick's Avatar
Default Re: Launching (Kermit EK)
i'd say around 4000-4500 try it and see, just slip the clutch, dont just drop it. But if it bogs down at 4000 then go higher, if it spins to much go lower. Good luck..
Old Feb 20, 2003 | 10:15 PM
Kermit EK's Avatar
Default Re: Launching (TeamTooQuick)
reaching for consistant 14s stock! I'll try tonight......
Old Feb 20, 2003 | 10:57 PM
AussieK24's Avatar
Need to know more about the setup. Particularly tyres/suspension...
Old Feb 21, 2003 | 12:11 AM
raene's Avatar
Default Re: Launching (b16a4me)
Exactly ie like what kind of car is the B16A in??
Personally I launch no higher than 3500 rpm and run about 22psi on street tires... mid-to-low 2.2s 60' times aren't that bad for a tire with treadwear 480
My times are in my sig.
Old Feb 21, 2003 | 04:27 AM
AussieK24's Avatar
Default Re: Launching (raene)
I leave at about 4500 and ride the clutch pretty hard. I wince everytime hehehe
I run 205/60 x 13's at about 12 psi
Old Feb 21, 2003 | 12:40 PM
Kermit EK's Avatar
i/h/e test pipe 2.5 exhaust suspension, ground control & kyb agx street tires 15x7 dunlops.
Old Feb 21, 2003 | 07:38 PM
civic596's Avatar
In mine I launch at 4500-5000. It is tricky. I am still learning. But upgrading my clutch wednsday. The stock clutch sucks. If you launch too high I have found that you hit v-tec before you get anywhere. Which sometimes helps.
Old Feb 21, 2003 | 08:29 PM
Default Re: Launching (civic596)
With 22x8 slicks i launched @7800rpm and did 1.8's solid B16a
Old Feb 22, 2003 | 07:08 PM
civic596's Avatar
Default Re: Launching (killerbseries)
The best I can get is 2.3's. (60 ft)
But that is in AZ.
Old Feb 23, 2003 | 01:41 PM
Ruby Civic's Avatar
with modded b16 and slicks w/ portflow head, itr hookup on the cams and intake manny etc. would launch at between 8 and 8500 rpms - that crap is crazy but it takes that to get out of the hole if your motor can take it - best 60 ft. in a 2570 lb. car was 1.78
Rob!
75
Jul 8, 2004 05:49 PM
EGhatched
Mar 22, 2004 09:47 PM
mattcalica
Jan 26, 2004 07:44 AM
OreoEF8
14
Jul 25, 2003 04:20 PM
CRXBart
May 29, 2003 01:48 PM
