About oil return/oil inlet how do i turn it around?
On my turbo its a garrett t3/04e i have it mounted so filter on left 5bolt on right...normal way.....and the oil return is facing up...and inlet facing down...it was rebuilt so is it possible it got floped. Can i just undo the bolts on the exhaust houseing and turn it around and put them back on?
like can i just unbolt the bolts around it..and pull it out turn it and bolt it back easily without hurting anything?
all you gotta do is loosen the 6 bolts on the compressor and loosen the 6 bolts on the turbine, you dont have to take them completely out, and then just twist the center section.
right ive alreayd 'clocked" the turbo and turned it how i want it..but then the compressor side where the oil inlet/return is mounted is facing upside down..the return is on top......inlet is on bottom....and its bolted to the exhaust housing...i was wondering can i just unbolt that center section and turn it?
