Did anyone ever have too......
Old Nov 2, 2001 | 06:14 AM
Speed PHreak's Avatar
Default Did anyone ever have too......
On their turbo, rotate the housings to fit properly? My center section is 180 out of turn. The oil feed is on the bottom, and the oil return is pointing "up".........
Old Nov 2, 2001 | 06:22 AM
Incognito's Avatar
Default Re: Did anyone ever have too...... (Speed PHreak)
Yes, sometimes they do have to be rotated to fit. There are bolts on the housing which U loosen up to allow movement.
Old Nov 2, 2001 | 06:25 AM
Default Re: Did anyone ever have too...... (Incognito)
Thanks for the quick reply dude, I figured as much but I just didn't want to losssen the bolts up and find that I needed to replace a seal or something because I rotated it.
Old Nov 2, 2001 | 06:58 AM
Blown90hatcH's Avatar
Clocking the turbo....yeah...just loosen then barely...it will turn. You can turn both sections around.
Jason
rtype11's Avatar
of course you have to how does the turbo manufacturer know the positioning of your motor/ic/oil feed etc.. use one half turn on the backing plate bolts on compessor side and rotate to the desired position, tighten and repeat on turbine side. make sure while rotating into position not to touch / damage blades.
Old Nov 2, 2001 | 10:11 AM
Default Re: Did anyone ever have too...... (rtype11)
Thank you to most for your pateince with my ignorance. I just paid 3k for something and I'd rather not F it up by taking something aprt i'm not suppose to. I was 90% sure that I'd have to rotate the housings, I just wanted confirmation.
Old Nov 2, 2001 | 10:24 AM
RGAZ's Avatar
New User
Oh yeah, rotating the center section is easily done. Two things to beware.
1. The exhaust side should be easier to move since it is almost always held on by plates and bolts. The compressor side can be tricky. Some turbos have big-a$$ snap-rings that can be a major bitch to remove. You have to remove it to rotate and it can be a pain to reassemble.
2. Check and re-check the torque on the bolts you loosen. I have had mine loosen on me more than once.
Good luck.
Randy
Old Nov 2, 2001 | 10:30 AM
Default Re: Did anyone ever have too...... (RGAZ)
Sweet info rgaz. Any particular torque on those bolts? Bost side of mine are held on by bolts......no snap rings thankfully
Old Nov 2, 2001 | 05:30 PM
Smashback's Avatar
This guy ... always jumping everybody's case. It's getting really, really old.
Old Nov 3, 2001 | 09:36 PM
Default Re: Did anyone ever have too...... (mplex2000)
Is red RTV gasket sealant suitable for use between the turbo and manifold? I hope so, b/c the guy helping me today insisted that it was......i'm just kinda wary tho....
Old Nov 4, 2001 | 10:58 PM
dbman96's Avatar
New User
I don't believe ANY gasket sealant will handle the temperature of the manifold/turbine interface. Most people just use a T3 turbine stainless steel gasket available at your friendly local ford dealer (gasket would fit a Thunderbird turbo, Mercur turbo, and any number of turbo trucks).
dturbo
Feb 10, 2005 08:15 PM
99Sivic
Feb 1, 2005 09:22 AM
JoseCuervo
Sep 21, 2004 10:37 PM
TurboB18C1
May 18, 2004 09:13 PM
gdrum
Jan 13, 2004 06:01 PM
