traces of oil.
Old Jan 1, 2002 | 10:43 PM
quikrpm'z's Avatar
Default traces of oil.
i found some oil around the oil return line coming off the turbo and on two of the bolts that attach the downpipe with the turbo. I sometimes have a bluish smoke during cold startup, and recently i changed the oil and had quite a bit of bluish smoke. Do u guys think its no biggie, or its a bad seal? tia.
[Modified by quikrpm, 11:44 PM 1/1/2002]
Old Jan 1, 2002 | 10:47 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: traces of oil. (quikrpm)
If its running down the oil return line, or the oil return line has oil on it, it may just be the oil drain flange's gasket. Very easy and cheap to fix..
art
Old Jan 1, 2002 | 10:53 PM
quikrpm'z's Avatar
Default Re: traces of oil. (Arturbo)
yeah the whole line did have residue on it, ill look into that gasket. What do u think about the two bolts having oil on them?
Old Jan 2, 2002 | 12:20 AM
Arturbo's Avatar
Better than steak
25 Year Member
I dont know what two bolts you are speaking of. Now, are these on the bolts that hold the downpipe flane on? Do you have a 5 or 4 bolt turbine flange?
art
kenbo21
Jul 30, 2008 05:36 PM
Heylookits shawn
May 22, 2007 06:13 PM
LSVtechnologytur...
Sep 17, 2005 01:46 PM
E Swift
Nov 2, 2002 09:17 AM
sutrusu
Aug 25, 2002 03:15 PM
