Oil Feed HELP!
Old Aug 19, 2006 | 11:22 PM
TH33G4MON3's Avatar
Default Oil Feed HELP!
So I have a question, sorry ahead of time for being a noob with boost.
Question- I just bolted up my turbo and intercooler piping etc. and noticed that my oil drain line on the turbo is more towards the top rather than the bottom. Is this bad, or will the oil still drain to the oil pan fine?
Thanks in advance! Oh and I did try to search.
Old Aug 19, 2006 | 11:34 PM
F20Cteg's Avatar
Default Re: Oil Feed HELP! (TH33G4MON3)
You need to "clock" the turbo so that the drain is facing straight down. Loosen the bolts around the center section "CHRA" and rotate the turbine and compressor housings to your likings and so that the drain is pointing straight down.
I said bolts, but some turbos have a V-band and a big spring clip.
Old Aug 19, 2006 | 11:35 PM
Hondoctors's Avatar
You need to loosen the bolts on both sides of the turbine and compressor housing and clock the center section so that the oil drain is pointed straight down, or close to it. You want the oil return to gravity feed back to the oil pan.
Old Aug 19, 2006 | 11:40 PM
TH33G4MON3's Avatar
Default Re: (Hondoctors)
Thats what I thought, thanks! And where the hell do I hook the oil feed up to on the back of the block? oh and its a 99 civic dx, I need a picture of where to tap it because pictures make life easier. or a good description.
Old Aug 20, 2006 | 01:03 AM
TH33G4MON3's Avatar
Default Re: (TH33G4MON3)
Anyone know where the feed line goes on the back of the block? Pics plz!
Old Aug 20, 2006 | 01:24 AM
TH33G4MON3's Avatar
Anyone?
Old Aug 20, 2006 | 01:43 AM
TH33G4MON3's Avatar
ok I know where it goes but whats the correct way to do this?
Old Aug 20, 2006 | 02:30 AM
shortyz21's Avatar
put a bspt fitting in the back of the block where the oil pressure sensor is, then run a line to the firewall and tee off that.
DO NOT PUT A TEE ON THE ENGINE.
Old Aug 20, 2006 | 08:40 AM
F20Cteg's Avatar
Old Aug 20, 2006 | 03:48 PM
psikotc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TH33G4MON3 &raquo;</TD></TR><TR><TD CLASS="quote">So I have a question, sorry ahead of time for being a noob with boost.
Thanks in advance! Oh and I did try to search. </TD></TR></TABLE>had a similar situation on my 1st turbo, blew the seals, fucked the turbo. save yourself the headache and clock it.
Old Aug 20, 2006 | 03:56 PM
EK k kay's Avatar
Default Re: (shortyz21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shortyz21 &raquo;</TD></TR><TR><TD CLASS="quote">put a bspt fitting in the back of the block where the oil pressure sensor is, then run a line to the firewall and tee off that.
DO NOT PUT A TEE ON THE ENGINE.</TD></TR></TABLE>
Tee's work fine. Just don't run anything other than the tee, oil feed line, and stock oil pressure sensor off it. More than half of this board runs tee's and they work with no problems. Don't overtighten the fitting.
Old Aug 20, 2006 | 04:23 PM
JoePSI's Avatar
Default Re: (EK k kay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK k kay &raquo;</TD></TR><TR><TD CLASS="quote">
Tee's work fine. Just don't run anything other than the tee, oil feed line, and stock oil pressure sensor off it. More than half of this board runs tee's and they work with no problems. Don't overtighten the fitting.</TD></TR></TABLE>
I run a T directly off my engine, one to the sensor and one for the feedline. No issues here.
Old Aug 20, 2006 | 04:35 PM
bb_one's Avatar
Default Re: (Public Enemy)
Just do whatever makes you sleep better at night, but I've seen many cars running a T off the block (feed line and OEM press. sender) without any issues.
Just make sure you get one that is 1/8 BSPT to NPT, not NPT to NPT.
Old Aug 20, 2006 | 07:24 PM
psikotc's Avatar
Granty Boy
Jun 4, 2010 07:52 AM
TEG777
Jul 19, 2005 10:25 PM
gdrum
Jan 13, 2004 06:01 PM
dave'sh22a4
Jan 21, 2003 07:41 PM
B20-T
Jul 29, 2002 06:01 AM
