All of those running the Sidewinder, how many of you are having trouble with heat?
Old Jan 11, 2004 | 09:11 PM
ITR9788's Avatar
Default All of those running the Sidewinder, how many of you are having trouble with heat?
I have been planning on running the Sidewinder for a while now, but many of the recent posts I have seen on it talk about having very high under the hood temps. Are any of you experiencing this?
Old Jan 11, 2004 | 10:43 PM
TrueNorthStar's Avatar
Default Re: All of those running the Sidewinder, how many of you are having trouble with heat? (ITR9788)
If you are worried about under hood temp problems, just get the manifold ceramic coated. It would even help your spool time too.
Old Jan 11, 2004 | 10:52 PM
JonGP4's Avatar
Default Re: All of those running the Sidewinder, how many of you are having trouble with heat? (TrueNorthSta
or you could wrap it in that header wrap
Old Jan 11, 2004 | 11:19 PM
Mr. Softee's Avatar
i had very high underhood temps with the SST.
Old Jan 12, 2004 | 06:05 AM
Tinker219's Avatar
The runner lengths on the SST and the SideWinder are very similar, so naturally so will the underhood heat. There are several ways to alleviate this:
-heat wrap(dont recommend, degrades material exponentially faster than open air).
-Ceramic coating helps, but doesnt cure
-Vented hood(ricey, but WORKS)
-remove the seal at the windsheild base, this will vent alot of air out
-stick some washers between the hood hinges, this will vent even more air out
-or be like me all last summer and say Xnay on the hood
Old Jan 12, 2004 | 06:23 AM
PM-Performance's Avatar
washers on the hood thing . hehehe never thought about that. people will think im running ITB's with my hood all up in the back , lol .
Is the under hood temps alot? I was told to watch for my CF hood melting?
Old Jan 12, 2004 | 06:53 AM
Tinker219's Avatar
youll be ok. CF will hold up to heat alot better than painted steel(providing its not DIRECT contact)
Old Jan 12, 2004 | 06:55 AM
i was hoping not.its not the nicest, but its nicer than stock .
its got some space, but i think its kinda close.
Old Jan 12, 2004 | 06:58 AM
ITR9788's Avatar
I thought about jet coating, but heard it hardly helped. The hood thing sounds pretty good though. I have a Teg, and have seen people remove the inner light to help vent.
Old Jan 12, 2004 | 07:04 AM
what for inner liner?i have no fender liners and dont have the rubber line on my hood anymore and the intercooler sits back behind the bumper and gives some space for air to come in , so i hope that helps.
Old Jan 12, 2004 | 07:05 AM
Tinker219's Avatar
Jet coating mainly helps with keeping the heat inside the runners(which is good for power production). No matter what though, you will still have heat conduction through the manifold material, and eventually through whatever coating is there.
Old Jan 12, 2004 | 07:56 AM
Bnjmn's Avatar
Fabbing up a heatshield would probably do some good as well. I would imagine just some thin Al sheet bent up would keep things under control.
Old Jan 12, 2004 | 12:44 PM
Default Re: All of those running the Sidewinder, how many of you are having trouble with heat? (Bnjmn)
Look at this:
http://www.hpcoatings.com/hipercoat_extreme.htm
They claim more than a 60% reduction of header/manifold skin temp.
Also swain does great coatings:
http://www.swaintech.com/autolc.html
They claim up to a 75% reduction in under hood temps.
Either of these are very good and you can still wrap the mani with thermal wrap.
Old Jan 12, 2004 | 12:56 PM
scooter's Avatar
my car was overheating until I wrapped it. After wrapping the mani the car has not done anything funny. I thought about venting the hood but I dont want rain running onto a hot manifold. I also cut some alluminum flashing from Home Depot and made a heat sheild for the under part of the hood so the heat doesnt bake off the paint.
scott
Modified by scooter at 3:41 PM 1/12/2004
Old Jan 12, 2004 | 01:37 PM
DIRep972's Avatar
Smarter than you
I don't know about the sidewinder but with my equal length tubular manifold my under the hood temps were ALOT higher then with a regular cast log manifold. Its definitly not a bad idea to do something to keep the heat in the manifold.
Old Jan 12, 2004 | 03:02 PM
JDogg's Avatar
Default Re: All of those running the Sidewinder, how many of you are having trouble with heat? (DIRep972)
we hacked a big *** hole in the hood to get rid of the heat and cause todd's (overblownmotorsports) manifold was hitting the hood. having manifold hangin out the hood is the new hotness
Old Jan 13, 2004 | 04:36 AM
Tinker219's Avatar
Default Re: All of those running the Sidewinder, how many of you are having trouble with heat? (JDogg)
Wonder how this will do 1/4" wall stock all around, high silicon ductile iron, they come ceramic coated with any color desired.
Oh, this is Cyphear's manifold, which will be dynoed today.
Old Jan 13, 2004 | 04:51 AM
B18Flip's Avatar
Default Re: All of those running the Sidewinder, how many of you are having trouble with heat? (Tinker219)
can't wait to see the dyno results!<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tinker219 &raquo;</TD></TR><TR><TD CLASS="quote">
Oh, this is Cyphear's manifold, which will be dynoed today.</TD></TR></TABLE>
boostedBLUfg2
Jul 16, 2011 07:15 PM
Scotty Dosent Know
Oct 6, 2007 09:48 AM
weezo182
46
Jan 30, 2006 03:00 PM
PM-Performance
May 4, 2004 11:48 AM
Andrew 825SM
Jun 14, 2003 02:02 PM
