searched: where to i tap the oil pan
Old Dec 25, 2003 | 12:18 PM
RedStarGsr's Avatar
Default searched: where to i tap the oil pan
if anyone had any pictures thatd be great..tryin to get the kit finished before the new year and i got a spare oil pan! yeaaa! thanks in advance...
btw: downpipe side will be on the passenger side
Old Dec 25, 2003 | 01:00 PM
wade's Avatar
Default Re: searched: where to i tap the oil pan (RedStarGsr)
ok, no one can answer that....what u do it go ahead and install the turbo and manifold, add the return line to turbo first, then add the hose and then aim the hose so it directly goes from the turbo return to oil pan. no sideways and angling of hose. it will crimp, like mine is, not good. Aim it striangt perpendicular into the oil pan.
tap the hole as high into the pan as u can but leave enuff room up top for the welding of fitting or threading if using a threaded fitting. too low and oil can go back into the return and block the incoming oil.
sorrry, i am rushed for time, hope this makes sense dan
Old Dec 25, 2003 | 03:19 PM
delslow94's Avatar
dan im gonna try and come down and i can show u where to put it. mine fits up pretty well...right spot basically cause it drains perfect. hit me up and well talk about a visit
Old Dec 25, 2003 | 03:27 PM
fventura03's Avatar
wade explained it how i would explain it
make sure the oil return line wont have any angling and bends, that can cause oil to not be able to go to the oil pan and it will make the turbo start burning oil, and creating a lot of smoke, not good. good luck
Old Dec 25, 2003 | 10:21 PM
neo1z's Avatar
Default Re: searched: where to i tap the oil pan (delslow94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delslow94 &raquo;</TD></TR><TR><TD CLASS="quote">dan im gonna try and come down and i can show u where to put it. mine fits up pretty well...right spot basically cause it drains perfect. hit me up and well talk about a visit</TD></TR></TABLE>
Sorry to butt in on the thread DK - but Marsh - did you get rid of that 21?
MalcolmV8
Dec 5, 2011 05:29 PM
delslow45
Apr 3, 2011 07:14 PM
ashb82
Mar 22, 2010 12:50 PM
toolowsol
Feb 9, 2006 01:52 PM
b00stedsi
Jul 28, 2002 04:17 PM
