help with cam install
me and my friend are installing a zex 59300 cam in his y8. We got the cam off and noticed we need a "cam key" I think is what its called to put in the groove on the new cam and to slide into the gear. Where do we get one of these?
You can get one from any adujstable cam gear. Also, since that cam is for the Z6 and not the Y8 you will need a gear to advance it 5 degrees so it is in its ) degree position. Go grab a skunk 2 gear.
we do have a skunk2 gear, but we need a key to align the gear onto the cam...you know the one that goes in the groove. I thought that there was one on the stock cam gear that comes off, but it seems that the notch is built into the gear so i guess I need to go buy a new one?
try a key from a b series- my str camgear didnt come with a key and i called them and they said to use one from a b series cause the stock d16 camgear has the key built right into it- this is on a skunk2 cam also. it might not be right but it very well could work.
also make sure you dont use an impact to tighten the gear, ive seen at least 3 cams break from ppl doing this, one was a zex cam, one was june and the other was toda, some exp. *** mistakes for being to lazy to tighten it the proper way.
gramentz
Aug 31, 2013 09:44 AM
krysted9354
20
Feb 19, 2012 12:04 PM
HybridIntegra
Apr 7, 2005 04:13 AM
v4lu3s
Mar 7, 2004 02:00 PM
thats why I said we have a skunk2 gear.
