my engine is almost done, but one problem with apr head studs HELP!
Old Oct 31, 2003 | 07:28 PM
G U E C O's Avatar
Default my engine is almost done, but one problem with apr head studs HELP!
i am almost dont building my engine, but i couldn't understand the arp instruction paper. i have a b18c1 long block. can someone clarify what to do, i hand tighten them, now what? how many pound so i torque it (80 or 75), i used the arp lubricant? and can anyone show me how to lub it, do i lube the top part where i install the nut too? damn arp should add pictures on there instructions.
Old Oct 31, 2003 | 07:59 PM
G U E C O's Avatar
Default Re: my engine is almost done, but one problem with apr head studs HELP! (stock93cx)
come on someone has to know
Old Oct 31, 2003 | 09:16 PM
G U E C O's Avatar
good night bump
Old Oct 31, 2003 | 09:30 PM
si1999's Avatar
clean the studs and the holes on the block. use a high strength loctite (red) on the threads of the stud. run them down with ur hand til they bottom out and then turn them back half a turn. put ur head on. apply arp moly lube to the end of the stud. then to both sides of the washer (if this kit comes with them) and the bottom of the nut. u have about 25 minutes to get the nuts on and torqued before the loctite begins to harden. torque the head down using the honda head torque sequence. torque them to 75 ft/lb... or what ur paper says for the arp moly lube..... any questions let me know.
Old Oct 31, 2003 | 09:38 PM
G U E C O's Avatar
o ****, i put the moly lub on the bottom and top of the thread. is that bad? damn the engine is at the shop right now.
Old Oct 31, 2003 | 09:40 PM
G U E C O's Avatar
i first torque it to 25, 50, 75, then 80 pund. does that sound correct
Old Oct 31, 2003 | 09:52 PM
si1999's Avatar
yep thats fine... just follow the honda pattern.. if u dont know what in talking about ask..
Old Nov 1, 2003 | 09:56 AM
G U E C O's Avatar
anyoine else think i did it right? did i lube it right?
Old Nov 1, 2003 | 11:31 AM
EG(6)SR's Avatar
Default Re: (si1999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si1999 &raquo;</TD></TR><TR><TD CLASS="quote">clean the studs and the holes on the block. use a high strength loctite (red) on the threads of the stud. run them down with ur hand til they bottom out and then turn them back half a turn. put ur head on. apply arp moly lube to the end of the stud. then to both sides of the washer (if this kit comes with them) and the bottom of the nut. u have about 25 minutes to get the nuts on and torqued before the loctite begins to harden. torque the head down using the honda head torque sequence. torque them to 75 ft/lb... or what ur paper says for the arp moly lube..... any questions let me know.</TD></TR></TABLE>
the instructions that come with the car are basically universal directions. But yeah, to the original poster, your doing it right. Thats basically exactly how I did it. Still not problems 4 months later with it boosting over other day.
Old Nov 1, 2003 | 12:08 PM
G U E C O's Avatar
was the loctite necessary
Old Nov 1, 2003 | 12:29 PM
Filliam H. Muffman's Avatar
Default Re: (stock93cx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stock93cx &raquo;</TD></TR><TR><TD CLASS="quote">was the loctite necessary</TD></TR></TABLE>
yes.
Old Nov 1, 2003 | 05:13 PM
AzG35's Avatar
Default Re: (JUN EK9)
I don't think loctite is absolutely necessary, I've never used it on the 4-5 sets of ARP studs I've installed and they have never had a problem holding. Just make sure you use the ARP lube and a good torque wrench when installing them.
Old Nov 1, 2003 | 10:23 PM
si1999's Avatar
the loctite is necessary to make sure they stay permently... and also to keep the studs from moving up and down or back and forth, which would wear away at the threads in the block.
Old Nov 1, 2003 | 10:45 PM
boostedcivicsir's Avatar
Mr. Badwrench
um if i remember correctly, they are to be put in dry, with no tools, but now they have the hex in the top. if you loctite, what happens if you pop a headgasket and need to deck the block? i dont think they are designed to be loctited. you use the supplied molylube on the threads on the nut side.
Old Nov 1, 2003 | 11:09 PM
G U E C O's Avatar
Default Re: (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">um if i remember correctly, they are to be put in dry, with no tools, but now they have the hex in the top. if you loctite, what happens if you pop a headgasket and need to deck the block? i dont think they are designed to be loctited. you use the supplied molylube on the threads on the nut side.</TD></TR></TABLE>
i called ARP and they said loctite is NOT to be used on this
Old Nov 2, 2003 | 09:17 AM
BatuKing's Avatar
i called ARP and they said loctite is NOT to be used on this</TD></TR></TABLE>
Yes.. they only suggest it if the stud is going to be located in a water jacket like some domestic cars
Old Nov 2, 2003 | 10:03 AM
G U E C O's Avatar
got it
hYbRid_Eg6
Jan 26, 2012 10:00 PM
95_red_dc
Aug 31, 2008 06:17 PM
boost fed ls
Jan 6, 2006 06:10 PM
flip1199
Aug 2, 2005 12:28 PM
LudEcrous
May 4, 2004 01:47 PM
