Torque values for arp head studs?
Old Jan 3, 2006 | 01:13 PM
boost fed ls's Avatar
Default Torque values for arp head studs?
When installing arp head studs to the block, what do you torque them down to?
I would search but it not working for me.
Old Jan 3, 2006 | 01:16 PM
SL0WEGG's Avatar
Default Re: Torque values for arp head studs? (boost fed ls)
are you talking about how tight it should be in the block before you put the head on? if so i believe their only suppsed to be hand tightened
Old Jan 3, 2006 | 01:28 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Torque values for arp head studs? (boostedej1)
yes when threading into the block, only hand tight.
Old Jan 3, 2006 | 03:27 PM
platinum00's Avatar
from my experiance with ARP studs, it's best to torque them down 10-15 ft/lbs before installing the head.
i know the instructions say hand tight, but i have had problems when there hand tight and never had a problem with torqued.
platinum.
Old Jan 3, 2006 | 05:30 PM
Default Re: Torque values for arp head studs? (platinum00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 &raquo;</TD></TR><TR><TD CLASS="quote">from my experiance with ARP studs, it's best to torque them down 10-15 ft/lbs before installing the head.
platinum.
Thanks
Old Jan 3, 2006 | 05:33 PM
hondaguyef's Avatar
Agreed. I've had headgasket problems when not doing this^^^. I believe it's from the stud turning farther into the block and getting a false torque reading.
Phil
Old Jan 3, 2006 | 05:44 PM
C M S's Avatar
platinum.
Great info, very true....
Old Jan 3, 2006 | 05:48 PM
Default Re: Torque values for arp head studs? (hondaguyef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyef &raquo;</TD></TR><TR><TD CLASS="quote">
Phil</TD></TR></TABLE>
I think thats what happend the first time, I am trying not to make the same mistake.
Old Jan 4, 2006 | 04:14 AM
USDM 4G VTEC's Avatar
i put the nut on the stud to get some grip and i turned it by hand hand until they stop by putting a wrench on the nut and turning it by my finger
Old Jan 4, 2006 | 07:34 AM
Everyones Hero's Avatar
Default Re: (USDM 4G VTEC)
I didn't have any of the moly lube when I went to install mine so I went to 15ft/lbs.
Remember to blow out the holes with compressed air, chase the threads, and blow them out again.
Torquing them into the block was a pain in the *** at first until I figured out how to do it.
Put a closed end wrench on the stud, put a nut on upside down, put a nut on the correct way and tighten them together. Torque the stud to 15ft/lbs and then remore the top nut. 2nd will come right off.
Old Jan 4, 2006 | 01:21 PM
Default Re: (Everyones Hero)
Next question is, what are the torque values when installing the head to the block? I know its a 3 step process.
Old Jan 4, 2006 | 01:24 PM
hondaguyef's Avatar
Default Re: (boost fed ls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boost fed ls &raquo;</TD></TR><TR><TD CLASS="quote">Next question is, what are the torque values when installing the head to the block? I know its a 3 step process.</TD></TR></TABLE>
I think i do, 40, 60, 70.(ft./lbs.)
Old Jan 4, 2006 | 01:29 PM
Default Re: (hondaguyef)
I think i do, 40, 60, 70.(ft./lbs.)</TD></TR></TABLE>
Thanks
Old Jan 6, 2006 | 07:39 AM
I thought it was 20, 40, 60, 75.
Old Jan 6, 2006 | 07:51 AM
rudebwoy's Avatar
10-15 lbs before installing the head huh? I've been following arp's specs, hand tight, and I am on my 3rd cometic head gasket in 7000kmiles, so I guess I will try doing the 15 ft lbs torque with this 3rd gasket, hope this is it.
Old Jan 6, 2006 | 06:10 PM
hotimportcrx's Avatar
Default Re: (rudebwoy)
defiently torue them down like 10-15 lbs before installing because the instructions say HAND TIGHT but hand tight to me ,you,....and anybody else may be different...especially considering chances are oil will be on your hands.....do this and you should have no problems.
hYbRid_Eg6
Jan 26, 2012 10:00 PM
95_red_dc
Aug 31, 2008 06:17 PM
george34
Feb 18, 2006 05:05 AM
flip1199
Aug 2, 2005 12:28 PM
LudEcrous
May 4, 2004 01:47 PM
