For all you turbo prelude's help
Old Oct 13, 2003 | 05:45 PM
ItzTw's Avatar
Default For all you turbo prelude's help
I have A 95 lude VTEC I am current running a drag gen 4 setup, AEM Fuel rail, DSM 450 injectors, E-manage, Greddy E-01, and vortec FMU. But I am still getting detonation..... what should I set my timing at? -7 or so? How should I go about not getting detonation? Suggestions please...
Old Oct 13, 2003 | 06:00 PM
PrecisionH23a's Avatar
Default Re: For all you turbo prelude's help (ItzTw)
You usually want to retard your timing only about 2 degrees from stock.
How much boost are you running when you detonate and how do you know you are detonating?
Old Oct 13, 2003 | 06:03 PM
ItzTw's Avatar
Default Re: For all you turbo prelude's help (GudeH23a)
I am only able to boost about 5psi, and it has like a slight pinging noise when boosting.
Old Oct 13, 2003 | 06:17 PM
What plugs are you running? Did you gap them to .028 - .030?
Old Oct 13, 2003 | 06:25 PM
ItzTw's Avatar
NGK plugs and yea I gapped then right
Old Oct 13, 2003 | 06:39 PM
are they a 7 series plug?
which specific plugs? part number?
Old Oct 13, 2003 | 07:16 PM
ItzTw's Avatar
I'll go look, let you know tomorrow
Old Oct 13, 2003 | 10:15 PM
I should have mentioned this earlier, but the plug i recommend is the NGK NGK BCPR7ES (part #3330).
If you are running the bkr7e's you should be ok and that is not why you are detonating... but I would recommend running the bcpr7es in the near future.
Old Oct 13, 2003 | 11:24 PM
flip1199's Avatar
what do u consider the right gap? What octane gas are u running?
Also how are u running the greddy emanage, 450's and a fmu??
Old Oct 14, 2003 | 01:41 PM
spoolinlude's Avatar
I live under a rock
Default Re: For all you turbo prelude's help (flip1199)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flip1199 &raquo;</TD></TR><TR><TD CLASS="quote">what do u consider the right gap? What octane gas are u running?
Also how are u running the greddy emanage, 450's and a fmu??</TD></TR></TABLE>
he said it above
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GudeH23A &raquo;</TD></TR><TR><TD CLASS="quote">What plugs are you running? Did you gap them to .028 - .030?</TD></TR></TABLE>
see
Old Oct 14, 2003 | 04:05 PM
ItzTw's Avatar
Default Re: For all you turbo prelude's help (spoolinlude)
I have the 450 turned down to about 60 duty cycle at full boost..
Old Oct 14, 2003 | 07:00 PM
fastludeh22's Avatar
suggestion is to sell ALL your fuel mgmt stuff. sell p13. get hondata s100 on p72 or similar.
or at leats get rid of the fmu and run the hack,
or at LEAST go to the dyno and have them tune it.
btw-do you have a msd btm or similar to retard w/boost(which is not need w/hondata, so you can sell that also)
Modified by fastludeh22 at 5:23 PM 10/15/2003
Old Oct 14, 2003 | 11:15 PM
safe driver's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ItzTw &raquo;</TD></TR><TR><TD CLASS="quote">AEM Fuel rail, DSM 450 injectors, E-manage, Greddy E-01, and vortec FMU. But I am still getting detonation..... </TD></TR></TABLE>
eww what a mess.. get rid of the FMU and the missing link/check valves if you have them. and retune. definitely invest in a wideband O2. DSM 450cc with the stock fuel pressure/pump is enough the make you run extremely rich. at 6k rpm and above i'm at -39 on the afc with an afr of 11.5... so that's how rich h22's run. as far as timing i'm only at -4 degrees and have no sign of detonation.
Old Oct 15, 2003 | 08:56 AM
Mikeyslude's Avatar
Default Re: For all you turbo prelude's help (safe driver)
what fuel pump?
Old Oct 15, 2003 | 04:28 PM
ItzTw's Avatar
Default Re: For all you turbo prelude's help (Mikeyslude)
I have a walbro fuel pump, Just took off the FMU but still haven't started the car (Its Raining). I also have a p72 here that I can hook up, Should I or would it run to lean? waiting for my friend to come over with a timing light so I can change the timing manualy.
(Where can I get a Wideband o2 at?) best place??? I just welded a second O2 Bung on to my downpipe.
Old Oct 15, 2003 | 08:03 PM
ItzTw's Avatar
Help Help help
Old Oct 15, 2003 | 08:22 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikeyslude &raquo;</TD></TR><TR><TD CLASS="quote">what fuel pump?</TD></TR></TABLE>
stock fuel pump
Old Oct 15, 2003 | 08:28 PM
not sure if it'll run lean or not. it all depends on your settings. start out at a setting where you're absolutely sure it'll rich and lean it out... while checking your spark plugs. if it's full black (with soot) then you're rich beyond 10afr. lean it out untill there's no more soot on the spark plug.
imo.. the techedge wb is the best deal out there. http://www.wbo2.com
Old Oct 17, 2003 | 04:10 PM
ItzTw's Avatar
Help help help
Old Oct 17, 2003 | 05:10 PM
Default Re: For all you turbo prelude's help (fastludeh22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastludeh22 &raquo;</TD></TR><TR><TD CLASS="quote">suggestion is to sell ALL your fuel mgmt stuff. sell p13. get hondata s100 on p72 or similar.
Modified by fastludeh22 at 5:23 PM 10/15/2003</TD></TR></TABLE>
there is all the help you need. and a good wideband is the new aem.
Old Oct 17, 2003 | 05:38 PM
SweepeR 7's Avatar
sorry but what does detonation mean?
CustomX113
Sep 18, 2006 01:21 PM
digkhangboyz
Dec 28, 2004 08:44 AM
r7
Aug 26, 2003 05:18 AM
TwistedHatch
Apr 25, 2003 11:47 PM
Sh4rky
Apr 2, 2002 01:34 AM
