so i changed my spark plugs.. .
so i changed my spark plugs today, and put in some bkr7e's ..
the ones i took out were ngk iridium 5's, with a .042 gap, i am no running bkr7e's with a .032 gap
can't really tell a difference yet.. . but sometimes it stuttered (misfired i think) with the 5's
is it damaging to run a 5 step spark plug?
Re: so i changed my spark plugs.. . (r7)
Depends, what state do you live in, what octane do you run, what compression do you run, how much do you boost and where is your timing set at?
I also put in a set of BKR7E's today, but I'm running a .30 gap http://www.sparkplugs.com
Did you get a lot of detonation from those plugs?
In most applications that I know of. when people go FI, they usually go a step or 2 colder with their plugs. It seems as though you went a step hotter for some reason.
I would think running a 5 series with boost would make your motor detonation prone.
Re: so i changed my spark plugs.. . (oscarmayer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oscarmayer »</TD></TR><TR><TD CLASS="quote">your supposed to be running 7's not 5's. 5 is stock and 7 is 2 steps colder than stock.</TD></TR></TABLE>
wich motor your talking about?
For most b series I know of, 6 is stock, and 7 is one step colder.
Re: so i changed my spark plugs.. . (LiLOtaku)
i am running 7's now
i said i had 5's.. anyhow, it would seem to misfire when the air is cool (nighttime)
edmonton, alberta, canada, b16a, stock internals, 5psi
Re: so i changed my spark plugs.. . (Happyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Happyman »</TD></TR><TR><TD CLASS="quote">Ya 6 is stock on the d16y8 as well.</TD></TR></TABLE>
I thought it was ZFR5F-11 is stock on the Y8. At least it was on my wifes 98 EX.
