wastgate wont stay shut.... need help asap!!!
Old Oct 11, 2003 | 01:31 PM
71 mgb's Avatar
Default wastgate wont stay shut.... need help asap!!!
i found out why my cars want making full boost... the WG is opening a bit so it only builds about 4psi... i unhooked the vac line and it spooled up at 3500rpm instead of 42k like it was before and it shots up to 7psi... so i have figured thare is something wrong with the vac line.. i have it teed into the break booster, along with my BOV, should i try taping in someware else??? if so where???
thanks for the help
chris
Old Oct 11, 2003 | 01:39 PM
twkdCD595's Avatar
Default Re: wastgate wont stay shut.... need help asap!!! (71 mgb)
what kind of wastegate, if its a deltagate you have to adjust them?
Old Oct 11, 2003 | 01:42 PM
71 mgb's Avatar
Default Re: wastgate wont stay shut.... need help asap!!! (twkdCD595)
35mm tial
Old Oct 11, 2003 | 01:50 PM
twkdCD595's Avatar
do you have that machined ring that goes in the bottom of the wastegate installed?
Old Oct 11, 2003 | 01:52 PM
71 mgb's Avatar
yep.. thare is no sine of it leaking from the ring or a blown gasket..
Old Oct 11, 2003 | 01:56 PM
twkdCD595's Avatar
have you tried changing vaccuum sources or anything like that? how many things do you have teed with the wategate source (just the bov?)? I would think the brake booster would be a good spot but maybe experiment with the different sources.
Old Oct 11, 2003 | 03:34 PM
civictypenos's Avatar
i was having the same problem,but with a internal wastegate.i just put one of those $5 boost controllers on it,works great,feels nice to get 10 psi now,lol.
i tried all kinds of stuff but could never get it to go higher,i know there was nothing wrong with the wastegte becuse i unhooked it and my psi went up to 15+ with no problems.i think someone said that the size of the vacuum line will make a difference,but i never changed that out to find out.
95teilhatch
Sep 30, 2007 01:57 PM
juniestyle
Feb 12, 2007 04:47 PM
PooOnMyShoe942
Sep 30, 2005 04:50 PM
l2yanE
Sep 18, 2005 09:11 PM
ProjectEG
Aug 13, 2003 04:18 PM
