wich nipple on the tial 35mm wg??????
Old Oct 6, 2003 | 09:27 AM
redhatchb18's Avatar
Default wich nipple on the tial 35mm wg??????
where do i run the lines from the wg? post pics if you have them.
Old Oct 6, 2003 | 09:33 AM
BROOD's Avatar
Default Re: wich nipple on the tial 35mm wg?????? (babyboib16)
Run the Vac source to the lower/side WG port, if your using the WG as is (no EBC).
Old Oct 6, 2003 | 09:40 AM
Default Re: wich nipple on the tial 35mm wg?????? (BROOD)
do i run it to the nipple on the turbo on the compressor housing?
Old Oct 6, 2003 | 09:43 AM
Foozball26's Avatar
Top is for boost controller whether manual or electronic
Side/Bottom is vacuum.
theres 2 ways to do this.
1. IF USING A BOOST CONTROLLER: hook the side port to the turbo outlet and the boost guauge to the MANIFOLD so you can adjust the boost.
2. If NOT using a boost controller, hook the side port to a MANIFOLD source.
Old Oct 6, 2003 | 09:50 AM
Default Re: wich nipple on the tial 35mm wg?????? (Foozball26)
some one told me to hook my boost guage to the fpr hose. and run the side nipple on the tial wg to the turbo. i dont have my boost controller yet but will have one in a month or 2. does this sound right?
Old Oct 6, 2003 | 11:01 AM
bump
Old Oct 6, 2003 | 11:29 AM
BROOD's Avatar
You will want a vac/boost (intake manifold) source. Something after the throttle body. You could tee into the brake booster source or tap strait from the intake manifold. I would not use the fpr line, it would be alittle small for the WG.
Taking the signal from the turbo compressor will not show the pressure drop across the intercooler and charge piping
Old Oct 7, 2003 | 04:37 AM
i am running the boost guage to the fpr line not the wg is that right? also what would be the best vac source for the wg? where on the intake mani?
Old Oct 7, 2003 | 05:55 AM
ok anyone?
Old Oct 7, 2003 | 06:16 AM
BROOD's Avatar
Anywhere on the intake manifold or tee into the brake booster line.
Old Oct 7, 2003 | 06:28 AM
can i run all to the same vac source for the wg, bov and boost guage?
Old Oct 7, 2003 | 06:42 AM
Tinker219's Avatar
if its a STRONG signal, ie, the brake booster...
Old Oct 7, 2003 | 02:26 PM
BUMP
Silva Bullit DC4
Jan 17, 2008 02:06 PM
GOIN V8 HUNTIN
Dec 10, 2006 10:51 AM
1boostedcivic
Sep 1, 2005 06:05 PM
importboi22
May 20, 2004 04:43 AM
99silverbullet
Jan 3, 2004 06:28 PM
