what should timming be set at w/ turbo?
Old Oct 1, 2003 | 10:10 PM
bumsta217's Avatar
Default what should timming be set at w/ turbo?
sup i have a 94 teg. I was wondering when boosting... do u retard the timing? or leave it stock? thanks a lot fo your help guys
Old Oct 1, 2003 | 10:51 PM
NuclearB18B's Avatar
Default Re: what should timming be set at w/ turbo? (bumsta217)
your setup would be helpful
Old Oct 2, 2003 | 07:49 AM
bumsta217's Avatar
Default Re: what should timming be set at w/ turbo? (ha illuminato un)
im running on a basic t25 setup with about 5lbs boost right now... would that help?
Old Oct 2, 2003 | 08:07 AM
highmilehatch's Avatar
Try using the search function. Be more specific than just "basic t25 setup with about 5lbs boost". Fuel? Engine management? Intercooled? I know your sig says 94 LS but who knows if the motors the same or stock. You need to help yourself before we can help you. I personally think on a B18b you can leave it at stock timing if your only running 5 psi on a t25 no matter what the fuel setup (assuming you have a boost referenced fuel supply).
Old Oct 2, 2003 | 08:23 AM
drvfast's Avatar
Default Re: what should timming be set at w/ turbo? (highmilehatch)
what would you recommed timing for a stock bottom end jdm b16 inline pro manifold sc50 running 9psi it is intercooled, walbro 255lph intank, rc 440's and smc to control fuel? thanks
R3X5150
Aug 28, 2013 05:23 PM
nvmyb20hatch
May 24, 2006 04:53 PM
Talon12bp
Feb 8, 2004 11:03 AM
-[95cxhatch]-
Feb 8, 2004 09:47 AM
SCsol
Jul 29, 2001 08:28 AM
