b18b turbo, timing questions please
just got my b18b turbo crx on the road. i am running a 10:1 FMU, stock injectors, and stock everything else, a missing link, and 5 PSI of boost... t3/t04e 57 trim.
How much ignition retard do i need to do this safely? i don't want to detonate in any way. But I want to feel ok about flooring it every once in a while. But right now, i just retarded the hell out of it, and its running laggy. So whats a safe timing retard to set per PSI for my setup at 5 to 6 PSI of boost?
Please, only speak from experience, I cant afford to lose an engine.
Thanks, Bryan...
Thanks, Bryan...
ok, so is it more an issue when I have more than 6 PSI?
I am just afraid to mess anything up since this is my daily driver. But 8 - 10 PSI would be so nice. once it hits boost it feels pretty decent at only 5 PSI. so lets say i went 8 PSI.... What is a reccomended timing retard per lb of boost? I just bought a timing light, and i kinda want to use it, for the better. So running 93 Octane gas and a conservative Timing Retard should let me make some decent numbers from my setup. I just want about 250 HP
Re: (Talon12bp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Talon12bp »</TD></TR><TR><TD CLASS="quote"> What is a reccomended timing retard per lb of boost? P</TD></TR></TABLE>
gereally about .5 per psi of boost, But like it was said before you don't really need to retard it until you go over about 5psi. I ran 7psi with stock timing on my b16 with no problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Talon12bp »</TD></TR><TR><TD CLASS="quote">ok, so lets say i went 8 PSI.... What is a reccomended timing retard per lb of boost? </TD></TR></TABLE>
Don't get greedy now, Remember your only runing a fmu with stock injectors, i wouldn't recomend more 5psi with your set-up.
Re: (B18badboy)
sorry, I forgot to mention that
255lph walbro pump.
It would be bad to go over 5 PSI on the stock injectors?
shouldn't I be able to go over 5 PSI with stock injectors?
I was thinking about trying 6 - 8 PSI
I just raced an EVO 8 from a 2nd gear roll, and he pulled a car on me in 2nd but once i hit 3rd i caught up right next to him and passed him by 2 cars in 4rth and another car and a half or so by the time i was in the middle of 5th.
I top out at almost 130 ish... kinda shitty, but its A GSR tranny, so better Acceleration through the gears.... I just need traction in 1st and 2nd. (sometimes 3rd) that GSR tranny helps alot with the GO.. but i wanted to see what 8 PSI could do since everyone here has at least 8 PSI, i mean, I really never heard of anyone running 4 here. i'd really like to try 6 or 8. but not if its not safe.... Im just wanting to run the boost all the other guys are running, and since i got a crx it takes less to go fast!. but that evo8 takes stock srt-4's from a 40 roll by about 2 cars. and i just beat the damn evo by 3 cars 3 times in a row.... and im on 4 PSI... Hes like what the f*** And im like,
"**** I didn't think it would pull that hard. I wonder what 8 PSI feels like?"
Whats up with that?
255lph walbro pump.
Whats up with that?
Re: (Talon12bp)
with stock injectors i wouldn't recomend going over 5-6psi.
Upgrade your injectors or your fuel management and you can run more. Run hondata and you can feel what 12psi is like easily.
Re: (b16ahybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16ahybrid »</TD></TR><TR><TD CLASS="quote">
gereally about .5 per psi of boost, But like it was said before you don't really need to retard it until you go over about 5psi.</TD></TR></TABLE>
I agree with B16aHybrid. If it were my car I wouldn't boost over 5lbs with that turbocharger on stock injectors. At least you are having fun at 5lbs man
