This is for all you single cam guys running lots of boost!!
Old Sep 29, 2003 | 09:54 AM
** OF HAZARD's Avatar
Default This is for all you single cam guys running lots of boost!!
I have a D16y8 block at home! I plan on fully building it. I just have a few questions... how much have you guys seen the stock sleeves hold? I also want to know what manegment you guys are using. One last question i want to be able to rev the motor past 8 grand...bad or good? If good what cams, valves blah blah blah would you recommend?
Thanks in advance!!
Old Sep 29, 2003 | 11:21 AM
VTC_CiViC's Avatar
Default Re: This is for all you single cam guys running lots of boost!! (91crdx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91crdx &raquo;</TD></TR><TR><TD CLASS="quote">how much have you guys seen the stock sleeves hold? </TD></TR></TABLE>
Over 20psi. Sleeves are made of the same material as B-series sleeves, and I belive somebody mentioned they might even be a hair thicker.. the sleeves will hold provided you take care of everything esle.
Old Sep 29, 2003 | 06:25 PM
scttydb411's Avatar
i run 10 psi daily totally stock. run the hack also. don't rev the stock head to 8 grand...ecu will prevent it anyway at cutoff.
once you decide to build up bottom and head you could boost past 20psi and rev to 8 grand, but better have something like hondata.
Old Sep 29, 2003 | 06:32 PM
MikeExt's Avatar
New User
Default Re: (scttydb411)
I run about 10psi low and 14-15psi high on stock sleeves, cp piston, eagle rods and Hondata though.
Old Sep 30, 2003 | 01:38 PM
Default Re: (MikeExt)
i know i am going to have to build the head but has anyone ran 20 + psi and took it past 8 grand i plan on also getting hondata!! I just wanna know if you have seen anyone take past 8! I plan on running about 20 pounds maybe more!
Old Sep 30, 2003 | 04:35 PM
T-sohctec's Avatar
Default Re: (91crdx)
I run mine up to 8K @ 10PSI all stock. As stated before as long as it's done properly (hondata) you shouldnt have any problems.
Old Sep 30, 2003 | 04:48 PM
minus's Avatar
a guy named cody down in salt lake ran 26psi on his stock sleeves in his y8 and ran a 12.0
Old Sep 30, 2003 | 05:04 PM
ladysman's Avatar
Default Re: (minus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by minus &raquo;</TD></TR><TR><TD CLASS="quote">a guy named cody down in salt lake ran 26psi on his stock sleeves in his y8 and ran a 12.0</TD></TR></TABLE>
Shitty time for that much boost!
I run 10 psi daily on a fully stock motor with a tuned Hondata. I will most likely turn it up for the heck of it since a fully built motor is sitting in my house begging to be put in.
b16bri
Feb 13, 2008 07:00 PM
HIboost
Jan 2, 2006 06:52 AM
B18 CYA
Apr 7, 2004 03:43 PM
I8ayellowcrayon
Jul 8, 2003 11:37 PM
98civicEX
Dec 18, 2002 08:33 PM
