NOOB How-To - Clocking A Turbo (mods/pro's please check)
Old Sep 28, 2003 | 11:26 PM
Street_Kings's Avatar
Default NOOB How-To - Clocking A Turbo (mods/pro's please check)
My Turbo, When installed, made my outlet face straight into the block, and the oil return/feed to be paralell to the ground. not good. Soooo...being a noob, i thought i would try to rotate/clock it, and hopefully this thread will help out somebody else out. (And it gives me a chance to see if i am doing it right )
Note: will edit upon feedback. Please dont PM, as i am still a trial user *AHEM* mods *Cough...*
Remove hose attached to internal WG. (external gate skip this step)
Loosen the 6 bolts securing compressor housing. (internal WG remove all bolts)
Remove Pin/Clip holding WG arm to swingvalve, Then remove whole assembly (external gate skip this step)
Loosen the 6 bolts securing turbine housing. (both internal and external, just loosen)
Now twist assembly into desired positions. (Internal WG, Place mounting brackets back on with WG assembly to the same position it was before to connect to swingvalve. Put screws and pin back on.)
When you have it to the correct positions, Tighen Bolts.
Internal Gates, Reattach Hose.
Any comments? Suggestions? Feedback?
EDIT: Sorry Pictures Are Crap. Taken With A Cell-Phone
Modified by Street_Kings at 8:42 AM 9/29/2003
Old Sep 28, 2003 | 11:40 PM
NuclearB18B's Avatar
Default Re: NOOB How-To - Clocking A Turbo (Street_Kings)
pictures suck...but otherwise everything else seems good
Old Sep 29, 2003 | 06:09 AM
Bnjmn's Avatar
Torque values??
Old Sep 29, 2003 | 07:11 AM
SIReg9's Avatar
Default Re: NOOB How-To - Clocking A Turbo (Bnjmn)
am i the only one that see's ****?
Old Sep 29, 2003 | 08:24 AM
civperc's Avatar
good instructions, but the pics are dark and fuzzy.
Old Sep 29, 2003 | 09:28 AM
NyQuiL's Avatar
Default Re: NOOB How-To - Clocking A Turbo (untensadude)
good write up man, the pics are bad but for a cell phone camera it isnt to shabby.
Old Sep 29, 2003 | 03:26 PM
Flamenco-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bnjmn &raquo;</TD></TR><TR><TD CLASS="quote">Torque values??</TD></TR></TABLE>
no need to torqued them down very tight, you will less likely be able to use torque wrench anyway. Tighten it and then do another 1/4 of a turn, and you'll be set.
stan
Old Sep 29, 2003 | 03:56 PM
Mr. Softee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Street_Kings &raquo;</TD></TR><TR><TD CLASS="quote">My Turbo, When installed, made my outlet face straight into the block, and the oil return/feed to be paralell to the ground. not good. Soooo...being a noob, i thought i would try to rotate/clock it, and hopefully this thread will help out somebody else out. (And it gives me a chance to see if i am doing it right )
Modified by Street_Kings at 8:42 AM 9/29/2003</TD></TR></TABLE>
WHAT THE **** IS THAT
Old Sep 29, 2003 | 05:06 PM
racinskittle's Avatar
Default Re: NOOB How-To - Clocking A Turbo (94goldjungsr)
You forgot the "STRUGGLE LIKE HELL" to get the exhaust side off. This is the biggest bitch to do in the world. Is there any simple way to do this?
Otherwise good write up. If i wouldn't have done it already, i'd be reading this
Old Sep 29, 2003 | 06:10 PM
Cramerox's Avatar
Default Re: NOOB How-To - Clocking A Turbo (racinskittle)
see avatar for extra muscle
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racinskittle &raquo;</TD></TR><TR><TD CLASS="quote">You forgot the "STRUGGLE LIKE HELL" to get the exhaust side off. This is the biggest bitch to do in the world. Is there any simple way to do this?
Otherwise good write up. If i wouldn't have done it already, i'd be reading this</TD></TR></TABLE>
Old Sep 29, 2003 | 06:22 PM
Muckman's Avatar
Moderator in Chief
This seems too simple to warrant a how to. Good write up tho
Old Sep 29, 2003 | 07:40 PM
hoya_10fintec's Avatar
damn... I don't know how some ppl get away with a simple twist with their turbos..
I had to take the exhaust side housing completely OFF 'cause there was NO WAY I could just twist it where I wanted.. it was a bitch to put back in, too. I just hope everything goes fine when I install and run it...
Good for you tho, and nice write up
Old Sep 29, 2003 | 11:04 PM
Kwuaymaikrup's Avatar
Default Re: NOOB How-To - Clocking A Turbo (hoya_10fintec)
Did Tinker sell you his old camera?
Good job man
Old Sep 29, 2003 | 11:13 PM
civcexcoupeblack's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94goldjungsr &raquo;</TD></TR><TR><TD CLASS="quote">
WHAT THE **** IS THAT</TD></TR></TABLE>
I know turbos get us all a lil happy...but no need to show us!
Old Sep 29, 2003 | 11:38 PM
Holy ****! LMAO!! I see it now! LOLOLOL...
Old Sep 29, 2003 | 11:39 PM
its a public domain server...4 other people use it to upload pics. I just deleted some of the stuff on there that i was told was no longer needed, and uploaded mine. HOWEVER, one of the other guys used the server to post **** to HondaHookUp, So if you viewed that post it may be in your cache. Sorry! will rename files/edit post tommorow.
EDIT: Im sure a few of you didnt mind the picture that some of you are seeing tho
Old Sep 29, 2003 | 11:44 PM
lazerus's Avatar
Default Re: (Street_Kings)
I dont recommend this way!
Old Sep 30, 2003 | 06:11 AM
Default Re: (lazerus)
why, did you break it?
DeyAinRdy4Ds
Jul 28, 2010 04:29 PM
D15Bbigred
May 18, 2007 03:03 PM
TurboB18C1
May 18, 2004 09:13 PM
youngkow
Jan 3, 2003 12:03 PM
zojirushi
Dec 2, 2002 08:54 AM
