Does oil coolers really help?
Old Sep 23, 2003 | 11:28 PM
SiHatchTurbo's Avatar
Default Does oil coolers really help?
I was wondering how much does oil coolers help out your motor?
Old Sep 24, 2003 | 12:44 AM
twkdCD595's Avatar
Default Re: Does oil coolers really help? (SiHatchTurbo)
it lower oil temp siginificantly if used properly (which can be associated with good engine conditions) but you will never really reap any major tangable results from this... nothing thats not going to be debateable, besides the temp. reduction in oil.
Old Sep 24, 2003 | 05:15 PM
yea im trying to figure out more ways to cool down my turbo once i put it in
Old Sep 24, 2003 | 05:24 PM
White Smoke's Avatar
i my honda
Global Mod
I love mine Good if you drive for any distance..
Old Sep 24, 2003 | 05:28 PM
earl's Avatar
Default Re: Does oil coolers really help? (si2die4)
it takes extra oil pressure to push the oil thru the cooler.
Old Sep 24, 2003 | 06:29 PM
BoostedH23a1's Avatar
Default Re: Does oil coolers really help? (earl)
man earl i sure hope my auto meter guage sucks or something cuase idling at 950 rpm im at like 8 oil psi. interstate driving at 4000rpm is 35psi is this about right? i have a turbo...
Old Sep 24, 2003 | 06:49 PM
Excelerate's Avatar
Default Re: Does oil coolers really help? (BoostedH23a1)
I know this question was to Earl but i on my 6th Gen Accord w/ F-Max kit.. im runnin at the very least 25psi of oil pressure at idle(~1100) and almost 90psi of oil pressure at WOT.. hope that help for reference
Old Sep 24, 2003 | 08:41 PM
Snafu-Si's Avatar
From: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
Default Re: Does oil coolers really help? (JPLockwood)
I'm run around 6-10 psi at idle after driving HARD,
and on the highway criuse, I'm always around 60psi.
In fact, whether it'd be a 35mph cruise, or a 70mph cruise, oil pressure is at 60-70.
Old Sep 24, 2003 | 09:55 PM
earl's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedH23a1 &raquo;</TD></TR><TR><TD CLASS="quote">man earl i sure hope my auto meter guage sucks or something cuase idling at 950 rpm im at like 8 oil psi. interstate driving at 4000rpm is 35psi is this about right? i have a turbo...</TD></TR></TABLE>Sounds too low to me. By any chance did you bottom out your car and dent the bottom of the oil pan?
If not, sometimes a highly restrictive cooler can hurt oil pressure quite a bit. I would try bypassing the cooler and see what it does to your pressure. Let us know if you try that. It would be interesting to see.
Old Sep 25, 2003 | 01:40 AM
89dxhunchback's Avatar
Oil cooler are just like intercoolers... Some flow REALLY well, but don't cool that well... Some flow poorly, but cool really well...
Flow vs cooling
line and tube size vs size on core.
An oil cooler between your motor and your turbo isn't going to do anything but extend the life of your turbo, and it reduces oil presure going to your turbo.
If you have a $200 used turbo, then I wouldn't use on unless you have a problem with oil "blowing by" the seals in the turbo..
IF you have a $1000 ball-bearing turbo, I'd get a cooler...
The oil cooler kits that are used between the oil filter and filter neck are too expensive for me..
$300 oil cooler, or get another $300 motor... The D is cheap...
I'd get an oil cooler for a $5000 ITR motor...
Old Sep 25, 2003 | 06:47 AM
i my honda
Global Mod
Default Re: Does oil coolers really help? (89dxhunchback)
I would NEVER put an oil cooler inline with my turbo. I dident even know thay made one for that small of a line?? The B&M Cooler I have cost me 120$ and also relocated my oil filter I havent seen any big loses in oil preasure here but im shure the pump is working hard...HeHe
Old Sep 25, 2003 | 07:34 AM
earl's Avatar
Putting a cooler on is NOT the proper way to drop oil pressure to your turbo. It effects the pressure to the whole engine.
Old Sep 25, 2003 | 07:45 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
I think if your not satying at 5-7k rpm over an extended period of time, i think it's not needed. Otherwise it's just another place where you will be concerned about oil leaks. That's just what i think tho.
Old Sep 25, 2003 | 09:50 AM
i my honda
Global Mod
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">Putting a cooler on is NOT the proper way to drop oil pressure to your turbo.</TD></TR></TABLE> What are you talking about? Who would want to drop oil pressure to the turbo? That is the stupidist thing I have ever heard.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">It effects the pressure to the whole engine.</TD></TR></TABLE>
Naturly
Old Sep 25, 2003 | 09:52 AM
i my honda
Global Mod
Actuly I was thinking about switching to an ITR - Watercooled Type for my road trips. What yal think?
Old Oct 1, 2003 | 06:11 PM
im not sure how that would work but... it might could happen
Supahr_Ed
May 27, 2006 11:51 AM
ham
Sep 29, 2005 12:49 PM
90crxzc
Dec 6, 2003 01:36 PM
DamonBoost
Jun 16, 2002 04:24 PM
rondigs
Jan 24, 2002 07:37 AM
