FMU???
Your new injectors are worthless to you, unless you have a reprogrammed ecu or AFC or something else to lower the duty-cycle of the injectors. You will probably idle fine, but as soon as you get on it, you will dump fuel and run like a turd and then probably blow your motor, since you're running check-valves or a missing link and can't tune for boost...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shotty527 »</TD></TR><TR><TD CLASS="quote">so could install the rail and reg. and wait on installing the injectors until i get hondata?</TD></TR></TABLE>
Yes you can. but then you can save yourself little work and put it all in at the same time. but wait till you get hondata for those injectors
Edit: make sure you get a right basemap for those injectors when you get hondata.
Cezilla
Mar 28, 2004 08:21 AM
