frankenstein k20/k24
Old Sep 14, 2003 | 01:05 PM
jeremy.'s Avatar
Default frankenstein k20/k24
does the rsx head bolt right on to the tsx block like a b16 head bolts onto a b18c block???
Old Sep 14, 2003 | 01:09 PM
Rhetoric's Avatar
Default Re: frankenstein k20/k24 (ek_jeremy)
i'd like to know as well. Is the K24 tsx block the same as the crv 03 model?
Old Sep 22, 2003 | 07:34 AM
chad's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek_jeremy &raquo;</TD></TR><TR><TD CLASS="quote">does the rsx head bolt right on to the tsx block like a b16 head bolts onto a b18c block???</TD></TR></TABLE>
yes
Old Sep 22, 2003 | 06:46 PM
brian g's Avatar
Even better, there is only one head bolt size for either K24 or K20.
If you want the water/oil cooler you will need to do some machining on the K24 block. Unless of course you have the TSX block.
brian g
Old Sep 22, 2003 | 06:54 PM
jeremy.'s Avatar
Default Re: frankenstein k20/k24 (brian g)
how much to the wheel does this produce? does compression drop?
willard steen
Apr 5, 2016 12:22 AM
absolut01gsr
Jun 4, 2008 04:55 PM
SilentHatch
Jan 6, 2007 12:06 PM
broliSI
Apr 2, 2003 04:26 PM
