retapping b18a1 block
Old Jan 5, 2007 | 10:31 PM
SilentHatch's Avatar
Default retapping b18a1 block
I have a b18a1 block, the previous owner had tapped the Head bolting ( where you bolt the head) well the tapping is stripped is there a way to retap?
Old Jan 6, 2007 | 07:23 AM
non-VTEC's Avatar
Default Re: retapping b18a1 block (SilentHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilentHatch &raquo;</TD></TR><TR><TD CLASS="quote">I have a b18a1 block, the previous owner had tapped the Head bolting ( where you bolt the head) well the tapping is stripped is there a way to retap? </TD></TR></TABLE>
hmmmm...probably not.....you might have to tap the hole to a larger size. the original size is a M11X1.5 you might have to step up to a M12X1.5
but you should have a good machine shop have a look at it before you try it......chances are they will tell you to just find a diffrent engine block since the B18A is easily avalible for cheap.
Old Jan 6, 2007 | 08:15 AM
Default Re: retapping b18a1 block (non-VTEC)
alright thanks...
Old Jan 6, 2007 | 09:27 AM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
yea, just get a new block.
Old Jan 6, 2007 | 12:06 PM
VRD^don's Avatar
Default Re: (full Circling)
http://www.hondamarketplace.co...27154
gooblinn258
Apr 22, 2014 08:50 AM
sivtechatchy
Mar 6, 2009 03:45 AM
skateboard_ej8
Apr 10, 2008 10:06 AM
hmtcrxsir
Mar 25, 2006 04:27 PM
Lewcis
Jul 29, 2004 09:19 PM
