forcing my wastegate open...any negative effects?
I'm planning on disconnecting my actuator arm to the wastegate lever/door. and putting a small spring to make the wastegate fully open. will this damage/ruin anything (engine, turbo components?)? Will this give me zero boost?
This is for a greddy 15g turbo kit out of the box
there's a simple answer to that . . . NO BOOST. If you leave the waistegate open then it can't build any pressure up inside . . . the turbine will spin, but you will not make any boost at all.
I want to bypass my turbo for autox....ive done it with boost and without boost, and i do the same if not better with na, even with less HP. I dont have an intercooler yet (smic on the way) and the its been really hot out in the autox field too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nd8ch »</TD></TR><TR><TD CLASS="quote">I want to bypass my turbo for autox....ive done it with boost and without boost, and i do the same if not better with na, even with less HP. I dont have an intercooler yet (smic on the way) and the its been really hot out in the autox field too.</TD></TR></TABLE>
Hmmm, well, I'm fairly sure you won't hurt anything.
I am thinking that setting your BC to zero would do effectively the same thing. Alot easier too. Especially if that is how your BC is connceted. As in, plumed to a vaccum hose at the WG so the WG is opened once the reference pressure is reached.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">Hmmm, well, I'm fairly sure you won't hurt anything.
nope. a boost controller cannot lower boost levels below the spring setting. the actuator/wastegate spring dictates minimum boost pressure. BC's only adjust above this threshold.
JUST2SPOOL
Feb 5, 2006 09:40 AM
