Some Turbo Questions
Old May 10, 2003 | 11:40 AM
TurBoXBirD16's Avatar
Default Some Turbo Questions
So... When my car is in neutral, there is no boost no matter how hard I step on my gas, right??
At that time, what is the turbo doing?? Is the wastegate opening so that there is no boost??
IF the wastegate is opening, that means I should see the internal wastegate rod moving to open the wastegate, right??
Please let me konw
thank you
Old May 10, 2003 | 11:47 AM
egg's Avatar
egg
Default Re: Some Turbo Questions (TurBoXBirD16)
a turbo builds boost based on RPM and engine load. when your revving your engine in neutral, you will get very little boost, depending on your turbo. the wastegate will be in the closed position until it reads the appropriate amount of boost for the actuator to open.
8YourV8
Jan 13, 2011 05:23 AM
avotegra
Nov 16, 2007 03:09 PM
1.8T_EG
Aug 7, 2003 07:30 PM
Screamer
Mar 28, 2003 10:01 AM
