How does a wastegate actuator work?
Old Feb 25, 2004 | 04:34 PM
hondafanatic1's Avatar
Default How does a wastegate actuator work?
Just what thje title says im confused because im not sure if the boost goes up when the wastegate flapper is close or when its open and when I put my actuator on my torbo the flapper is cosed tight does it open when I start the car or what?
Old Feb 25, 2004 | 04:59 PM
TrueNorthStar's Avatar
Default Re: How does a wastegate actuator work? (hondafanatic1)
Basically the waistgate "flapper" as you put it, opens when the desired boost level is reached. This bleeds of the pressure between your head and turbo which lowers the amount of boost the turbo is producing.
Old Feb 25, 2004 | 05:16 PM
b16ahybrid's Avatar
Default Re: How does a wastegate actuator work? (TrueNorthStar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TrueNorthStar &raquo;</TD></TR><TR><TD CLASS="quote">Basically the waistgate "flapper" as you put it, opens when the desired boost level is reached. This bleeds of the pressure between your head and turbo which lowers the amount of boost the turbo is producing.</TD></TR></TABLE>
Basically what he said, it is closed until preset boost is reached. Actually it starts to open before then, but isn't open fully until max boost is reached. It just allows exhaust gasses to bypass the exhaust blades, thus limiting the boost made by the turbo
Old Feb 26, 2004 | 03:45 AM
Default Re: How does a wastegate actuator work? (b16ahybrid)
I extended the wastegate actuator rod so the peset boost isnt to high.I have a home depot homemade boost controller.Hoiw do I use that to set the boost to like 6.5 psi?I have a tdo5h and somebody told me the actuator is preset at 10psi and thats way to high my application right now.
Thanks
Old Feb 26, 2004 | 06:13 AM
kpt4321's Avatar
The actuator is set at 9-10 psi, and there is no way around that. You should have thought of that before you bought the turbo.
You can't lengthen the rod, because it will give you absurd amounts of lag.
avsrule414
Dec 10, 2005 09:07 AM
nd8ch
Aug 26, 2003 04:47 AM
ceemarun
May 8, 2002 12:35 AM
Duck Sauce
Dec 6, 2001 03:36 PM
