No boost aaaarghhh!!!!
Old Aug 11, 2003 | 10:07 PM
musclefella's Avatar
Default No boost aaaarghhh!!!!
Okay i just temporarily installed my homemade turbo, just to test it a little, but there is no boost at all. I have a Garrett t3/t4 compressor 60 a/r housing, 60 trimwheel. Turbine63 a/r housing brand new and a tail waste gate with 0.9 bar spring.
When i test my car i can really hear the wastegate, but it sounds like it's open al the time. All the piping is triple checked.
I installed the wastegate on the flange on the turbomanifold.
Can anyone tell me what i did wrong???
thnx
Old Aug 11, 2003 | 10:45 PM
PrecisionH23a's Avatar
Default Re: No boost aaaarghhh!!!! (musclefella)
did you install check valves and new plugs gapped to .030-.032?
Old Aug 11, 2003 | 11:27 PM
flip1199's Avatar
Default Re: No boost aaaarghhh!!!! (GudeH23a)
did u install a vacuum line from the wastegate to charge system?
Old Aug 11, 2003 | 11:58 PM
Yeah i installed bkr8e ngk plugs, but i don't know what gap size?
I also have MSD 6 al and MSD BTM
4 Check valves are in place to.
What do the plugs have to do with no boost???
Thxn for the info
Old Aug 12, 2003 | 12:01 AM
Default Re: No boost aaaarghhh!!!! (flip1199)
I'll be checking that as soon as i get from work thanks, i'll let you know.
Old Aug 12, 2003 | 06:03 AM
i would run the bkr7e-11's if i were you and gap them to .030 to .032
Also, get rid of those check valves and buy a missing link map sensor.
As far as boost go, if the plugs are not gapped properly the spark will get blown out due to boost. Therefore causing hesitation while undergoing boost.
Old Aug 12, 2003 | 09:07 AM
Wastegate to turbo, with a t bone to my boostcontroller
Old Aug 12, 2003 | 09:18 AM
I'm gonna buy the zfrf7f-11. What do you think of those?? How do i gap them?? With a small metal messure plate 0.32??
Check valves are temp only. Where can i get those missing links map sensors?? you have one for sale is that the one i need, i'll buy it from you??
I live in Europe and the have jack & **** here..........and jack left town.
As soon as i know how to gap the sprak plugs, i'll be doing another test run.
lsvtechatch92
May 13, 2010 03:40 PM
madracer
Sep 14, 2008 12:36 PM
geezer_187
May 29, 2006 03:22 PM
hondaguyexsi
Aug 10, 2005 12:00 PM
integratuner94
Nov 3, 2004 03:40 PM
